Vise Stand Wheel Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2007, 08:39 PM
I just made a vise stand over the weekend out of an old steel wheel and axle. It is pretty hefty and was wanting to add a caster or two to help move it around. I can't figure out how to do this. Because the wheel is round, it would be hard to bolt a caster to it. Has anyone built one themself that I can steal ideas from?
Thanks,
Peter
Old 07-29-2007, 10:07 PM
Vise Stand
I would suggest that use it the way it is for awhile to try it out. In the end I think the wheel will need concrete poured in it to keep the stand from moving around when the vice is being used. IMO, you can always tip it up on the edge of the rim and roll it to where it needs to be.
Old 07-29-2007, 10:10 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I agree with everything he just said. I think you will need more weight and tipped it should roll wherever you need it to go.
Old 07-29-2007, 10:21 PM
I was using it today and it actually functions pretty well. I too thought it would need some more weight added to it but it was VERY sturdy. I was wheeling it around on its side but thought that some cheap casters would make it even easier. Just an idea.
Old 07-30-2007, 04:35 AM
garyroushkolb's Avatar
Last wiki edit: How to find an electrical drain Last photo:
vice on a stick
I agree leave off the castors. Mine's just on a 2" steel disk plate that sometimes isn't heavy enough and isn't a problem to move. If you have to move it a long way just use a 2 wheel dolley.
Old 07-31-2007, 02:42 AM
I'm leaning toward no casters myself, but you could screw the bottom of the wheel to a chunk of 3/4" plywood and screw some locking casters to the bottom of that.
Old 07-31-2007, 07:52 AM
dinger's Avatar
Jim's got the right idea, if you did put casters on the stand, it would be tough to use it with it rolling all over the place while you're trying to work. Dan
Old 07-31-2007, 10:59 AM
it looks like its balanced, i see a wheel weight on the wheel. good fab job, i like it.
Old 07-31-2007, 05:17 PM
Thanks for the comment. I am going to leave it the way that it is. It is really well balanced.
Old 07-31-2007, 06:09 PM
Spartyon,
I made a stand just like yours. It works well and it is very stable. What I did so I could move it around BUT not have it on the wheels all of the time was to weld on two pieces of flat quarter inch plate about eight inches apart. I drilled two 1/2 inch holes on the outer edge so I could install a 1/2 inch solid bar with two 8 inch hard rubber wheels mounted on the ends of the bar. The wheels are off the ground by about 1/4 inch when the stand is in-use. But when I need to move to another part of the shop I tilt the stand back onto the wheels and it goes where ever I want. Once I get to the new place I let it rock back on the rim.
Scholman
Old 07-31-2007, 09:48 PM
Originally Posted by scholman
Spartyon,
Scholman
That is exactly what I was refering to. Any pictures by chance?
Old 08-01-2007, 06:48 PM
Spartyon,
Sorry, no I do not have any pictures.
Scholman
Old 08-05-2007, 04:18 PM
stand
I made on like Sparton's. I took two non turning casters, welded amd brace them to the wheel as Sparton described. Just tack them in place to try it. I can't take a picture of mine until Tuesday. Perri
Old 08-08-2007, 02:39 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
Get two pieces of 1/4" flat bar steel get them at the same length and weld them to the bottom of the rim (edge that meets the ground). Be sure to position them so they stick outside the rim about a 1". Not drill one hole per lug for your caster wheels (be sure to get the casters with the one stud mounting!) that way you can pull the casters on or off as you like.
I agree with everybody else here, add more weight to the base. Go to home depot and get a 60# of concrete, mix it up and fill the top of your rim with it, be sure to smooth it nice and smooth! (Name, date, & hand prints are optional!) ...that way if dust, crumbs, grinding power, or slag gets on top it will be easier to brush off. My $0.02 Good Luck!!! ...Mark
Old 08-08-2007, 04:47 PM
Youngster's Avatar
Vice stand
Scholman has the right idea. When I got my horz./vert. band saw, I didn't like the height or the little dance it did when ever I tried to move it. A new frame was built out of 1" sq. tubing and a pair of wheels 1/8" off the floor. If you try this, set the saw in the vert. position with the table plate on to get the height you want. Oh yeah, throw the table plate that came with your saw in the scrap bin and make one about 6" sq. out of 3/16 or 1/4" plate. Don't worry about the miter slot. It never works anyway. Youngster.
control arm bushings montea Suspension - Brakes - Steering 15 04-22-2007 07:06 PM
Rod vise? strikingthematch Engine 3 08-15-2004 12:34 PM
