Vmatic 2 shift problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2006, 10:43 PM
I have a 79 Camero with a TCI Street and Strip TH350 with a Vmatic 2 shifter. The trans shifts great in automatic but in manual it will not shift from first to second. I ratchet from first to second and it stays in first. When I ratchet again it goes from first to third. Can anyone help?
Old 12-17-2006, 10:50 AM
Crosley's Avatar
Wiki Edits: 1659
If the shifter is adjusted correctly , I would think the next thing is to call TCI and ask them about the tranny.
Is the detent cable hooked up & adjusted?
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
Yargh, carbureator problem is driving me nuts (but not my car!) caustic meatloaf Engine 12 05-21-2006 12:41 PM
TH 350 1-2 Manual shift Feel HarderTranz Transmission - Rearend 3 05-16-2006 09:20 PM
TransGo 700 Performance Shift Kit Problem edge Transmission - Rearend 1 08-02-2004 12:47 PM
TH-350, low rpm 1/2 shift gearhead_383 Transmission - Rearend 7 10-30-2003 08:52 AM
