Volare susp on `59 Chev Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2003, 11:08 AM
Post Volare susp on `59 Chev Truck
Does anyone offer templates for cutting out the frame on a `55-59 Chevy Truck to weld in a volare front suspension?
Old 01-02-2003, 09:19 PM
BOBCRMAN@aol.com's Avatar
Post
did one on a Ford and only needed a few notches cut, they were very evident once we slid the suspension unit under the frame. made a good setup but had to adjust ride height.
Old 01-31-2003, 10:19 PM
New Member
Post
Hey, I did a '59 Chev. with a volare. What would you like to know?
[ January 31, 2003: Message edited by: magster65 ]
[ January 31, 2003: Message edited by: magster65 ]</p>
Old 01-31-2003, 11:15 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
Post
i have some pics of one being done, if you want them let me know......joe
Old 02-01-2003, 12:24 PM
murrsue's Avatar
Last journal entry: 57 pickup 8.8 rear axle install
Post
I saw one in progress and the guy had to narrow the 4" frame channel down to 3" to accept the Volare unit. He cut from the top of the frame channel ( the top part of the "c" shape) and just started back of where the new unit goes in and made a nice gentle sloping cut downward until it became 3".The starting point is not critical. He then welded a new piece of metal the same width, replacing the top of the channel. He also boxed the frame from the new Volare unit back some toward the rear of the truck for added strength. He did this on a bare frame (cab off) but I'm sure it could be done with the front end stripped back to the cab. One advantage of the Volare is that you can retain the original frame all the way to the front. It also has some height adjustment.
I WOULD LIKE TO KNOW more about building motor mounts for this upgrade. How does one know where to position etc. Someone said mount the engine off center 1 1/2" toward the pass. side to allow more room for exhaust around the steering box.
ALSO what headers to use? for a 350 engine.
I can be reached at murrsue@hotmail.com. Thanks
murray
Old 02-01-2003, 12:27 PM
murrsue's Avatar
Post
By the way Magster, your truck looks awesome! What color is that?
murray
Old 02-02-2003, 02:43 AM
New Member
Post
Thanks. It's Dupont Chroma-Premier BS702.
:p
