volt gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2010, 12:27 PM
volt gauge
i hooked up a volt gauge with the hot wire going to a switched terminal on the fuse panel and the black wire grounded is this correct? also should the gauge
show a steady 12 volts when running? 2nd question, my fuel was working
good then it started going to full when i turned the switch on. is this a
ground problem? my car is a 1966 buick skylark convertible .
thank you to all who reply!
Old 02-18-2010, 01:31 PM
T-bucket23's Avatar
Wiki Edits: 26
Sounds like you connected the volt gauge properly. Your voltage sounds low, when running you should be in the 14 volt range.
Your fuel gauge is is either a bad sender or bad wiring most likely.
Chet
Old 02-18-2010, 05:33 PM
302 Z28's Avatar
It is best to power a volt gage from the juncture that feeds your fuse panel. That way you get a more accurate voltage measurement.
Vince
Volt gauge problem.. APalusky Electrical 5 07-12-2009 01:34 PM
removing amp/installing volt gauge gary35 Electrical 1 02-11-2009 07:22 PM
Guages are dead gtipton Electrical 4 05-09-2007 09:14 PM
Gauge wiring on 6 volt to 12 volt JeffB Electrical 6 10-28-2006 09:28 AM
Volt Gauge hook-up 66pontiac Electrical 2 09-12-2005 06:51 PM
