Volt gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2005, 09:49 AM
Volt gauge
hey guys.i have a auto meter volt gauge.when i hook up the battery the needle shoots all the way to the right.Should this happen?The car isnt running will the needle drop once the car starts? hope you can help. randy
Old 02-03-2005, 10:17 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
no
It's just a voltmeter. It should read battery volts. When you start the car it should rise to alternator volts.
Old 02-03-2005, 12:16 PM
Frisco's Avatar
Glad To Be Here
Re: Volt gauge
You have it wired wrong.
There should not be any reading with the ignition switch in the OFF position. When the key is turned to the ON position you will read the battery voltage. Once the engine has been started, the gauge should read the alternator output.
