voltage divider or not ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2014, 08:34 PM
OK , it's a '57 Chev truck, which of course is 12 volts, BUT, did 'they' or did they not... use a voltage divider to reduce the voltage from 12 to 6 so they could continue using 6 volt gages ? Now I know for a fact, some vehicles used them up in to the 70's. At one time even NAPA had them on hand. But everyplace I check now , says 12 volts have 12 volt gages. Any one know this for sure ????thanks
Old 03-20-2014, 09:24 PM
Joe G's Avatar
Nope. When GM switched to 12 volt electrical systems in 1955, they used 12 volt gauges right away on both cars and trucks.
Old 03-21-2014, 09:49 AM
thanks, that explains a lot !
Old 03-21-2014, 01:12 PM
Only the ignition, there is a resistor or resistive wire that maintains 6 to 9 volts on the coil in the "run" position of the switch. Everything else is full time 12 volts. Starting uses full battery voltage on the coil which during cranking usually drops from 12 to 8 or 9 volts.
Bogie
Old 03-21-2014, 04:47 PM
I got it ! was confused, cause some others did use them , and the gages in this one didn't work, I guess got more checking to do ....
67 Pontiac 400 water pump divider plates ClassicMuscle Engine 14 08-21-2016 09:17 PM
64 impala rear seat divider welderbob Interior 7 08-16-2011 08:38 PM
Performer RPM Air Gap plenum divider info v8hed Engine 8 07-31-2011 04:59 PM
RPM Intake Center Divider ssmonty Engine 5 04-24-2009 10:22 PM
Edelbrok TORQUER II divider? Augusto Engine 17 07-10-2006 07:44 AM
