-   -   Voltage Drop (http://www.hotrodders.com/forum/voltage-drop-17810.html)
Nick Davis 06-14-2003 12:24 AM
Voltage Drop
I have a '72 442 convertible I purchased new. When I use one electrical accessory such as the power windows when another is running, the accessory seems to run slightly dim or slowly. The alternator output and battery output seem to be okay. Could a 31-year old wiring harness have an increasingly high voltage drop? That's a little more complex for me to check.
Thanks for any experience.
crazy larry 06-14-2003 12:44 AM
check the voltage regulator. i have $5 on the voltage regulator.....:mwink:
Nick Davis 06-14-2003 01:46 AM
Thanks for the tip. My car has an integral voltage regulator, but I'll see what develops.
Thanks again.
P.S. Years ago, tracking down problems used to be a lot easier!
horvath 06-14-2003 07:35 PM
31 years can do a lot of things to wires, eh? MAYBE there's a weak connection somewhere?
Alan
54 Chevy Pickup
4 Jaw Chuck 06-14-2003 08:19 PM
What's your idle speed? Sometime raising it a little is all you need.
rnpit 06-16-2003 01:17 PM
Take a look at all the grounds. All those years of moisture will leave the connecting points pretty rusted.
Nick Davis 06-16-2003 02:48 PM
Voltage Drop
Thanks for the idea. A little sandpaper, some WD-40 and a skosh more idle speed may fix the problem.
