Voltage Drop - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2003, 12:24 AM
OLDS Guy
Voltage Drop
I have a '72 442 convertible I purchased new. When I use one electrical accessory such as the power windows when another is running, the accessory seems to run slightly dim or slowly. The alternator output and battery output seem to be okay. Could a 31-year old wiring harness have an increasingly high voltage drop? That's a little more complex for me to check.
Thanks for any experience.
Old 06-14-2003, 12:44 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
check the voltage regulator. i have $5 on the voltage regulator.....
Old 06-14-2003, 01:46 AM
OLDS Guy
Thanks for the tip. My car has an integral voltage regulator, but I'll see what develops.
Thanks again.
P.S. Years ago, tracking down problems used to be a lot easier!
Old 06-14-2003, 07:35 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
31 years can do a lot of things to wires, eh? MAYBE there's a weak connection somewhere?
Alan
54 Chevy Pickup
Old 06-14-2003, 08:19 PM
4 Jaw Chuck's Avatar
What's your idle speed? Sometime raising it a little is all you need.
— Han Solo
Old 06-16-2003, 01:17 PM
rnpit's Avatar
Take a look at all the grounds. All those years of moisture will leave the connecting points pretty rusted.
Old 06-16-2003, 02:48 PM
OLDS Guy
Voltage Drop
Thanks for the idea. A little sandpaper, some WD-40 and a skosh more idle speed may fix the problem.
