voltage drop
I have been troublshooting this problem for some time now, I have a voltage drop when my electric fans kick on and even more when I turn on my lights (around 11 volts). How can I keep the volts at 13 or better with all that is running.
I have a 1 wire 100amp alterternator (chrome) ( flexalite dual fans) with a crate 502/450 hp in a 1970 Chevelle. |
thanks for the info I will try this on my car.
which one is the #2 terminal on the alt. Is it the top or the bottom of the alt. (under the rubber plug). the article said to hook a wire from #2 terminal to the "bat" terminal, is that the bat on the alt. or the battery itself?
voltage drop
I followed what the attached told me to do but when I wired it to
the horn relay it had constant power going thru it still and drain the battery. I need help to do this right. |
bad502,
Just saw your post. You have probably solved by now but if not try this site. All the info you need is there. Jesse www.madelectrical.com |
