Voltage drops under load when engine is warm - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2010, 01:45 PM
Last journal entry: Bringing home the 401 Nailhead
I have a 1996 Astro Van. When the engine reaches operating temp the voltage will slowly drop till the light comes on when ever I put a load on (fan, lights, etc). If I shut off the load the voltage will rise back to 14V. Only happens when the engine is warm. The alternator is less than a year old and checks out OK. Did not notice this till a few weeks ago. Battery was 5 yrs old so I replaced it. I am thinking this is a loose/corroded connection. I have checked the obvious places and now looking for suggestions.
Thanks
Old 07-20-2010, 02:07 PM
Thanks
you still got the rubber coating on the battery cables ?
they corrode between the innards ,cut off and clean
Old 07-20-2010, 05:05 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Thanks
The battery is a good suspect as it should have ample reserve capacity and hold a charge well for a good length of time. You should be able to hit it with a load test ( after charing the battery with a charger) and get 200 amps without falling below 10 or 9.6 volts and sustain that for about 15 seconds. If you have a midtronics tester they are pretty accurate and take all the guess work out of it. If the battery tests good then I would suspect the alternator has an internal problem like diodes open circuit or a regulator that is washing out with heat.
Old 07-21-2010, 04:59 AM
Since it was doing this before the battery was replaced I am doubting it is the battery. I did notice yesterday that it does this with out a load only not as radical. The voltage slowly drops to <12V and then climbs back to 14V. It is almost like a hot/cold cycle. This is pointing me to the alternator even though it is almost new. Will swap it out this weekend.
Thanks for the suggestions.
Old 07-21-2010, 08:52 AM
T-bucket23's Avatar
Wiki Edits: 26
You most likely have a bad connection. I would check all grounds and main feeds. I would be willing to bet you find a bad ground connection somewhere. As the engine warms the connection will get worse if it is loose.
Chet
How Does A Thermostat Work? cobalt327 Hotrodding Basics 16 03-16-2010 06:32 AM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
Warm engine problem, no power 78transam Engine 14 05-10-2006 07:19 AM
Hotrodders Knowledge Base: Engine Jon Engine 0 11-26-2005 06:17 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 07:26 PM
