Voltage Readings on New Gauge - Overcharging? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2003, 08:18 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post Voltage Readings on New Gauge - Overcharging?
My new Dolphin gauges are in ... and I'm curious about the Voltage meter :
When the ignition is on and the engine off, initially, the meter reads around 11 volts ... then after starting the engine, the meter reads up around 16 volts -- is that too high? Or is it cool?
Thanks.
Alan Horvath
<a href="http://AlanHorvath.com/54chevy/" target="_blank">54 Chevy Pickup</a>
Old 05-11-2003, 08:41 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Post
sounds cool man. alt. charging. far out. keep us posted on the ezwire. if it works, i'd rather spend 179 too.
Old 05-11-2003, 08:51 AM
horvath's Avatar
Post
Thanks, Larry
Thje EZ-Wire kit works great! Go for it, bro'.
Alan
Old 05-11-2003, 09:18 AM
joes50's Avatar
Post
Something sounds wrong.......11 volts wouldn't even crank over the engine. Check the voltage on the battery itself and then look at the reading on the gauge to see how they compare. The 16 volt charging is way to high and will boil out the battery. You should be around 13 volts.
Old 05-11-2003, 09:35 AM
dmorris1200's Avatar
doesn't play well with others
Post
Something is definately wrong with those numbers. Whether or not it's wiring problems or gauge error can't say. Get a digital multimeter and check battery voltage at the battery posts. Approx. 12.6 volts is fully charged and like the minute hands of a clock, 12.45v is 3/4 charged (45 minutes=3/4 of an hour). 12.30v is half charged (30 minutes=half an hour). Sounds like you are going to need to do a little investigating. Make sure all connections are clean and also check charging voltage at battery with multimeter and compare to gauge readings.
BUILT FORD TOUGH
Old 05-11-2003, 09:38 AM
Post
Also keep in mind that batteries carry a surface charge after charging. It's good to run some lights for a couple before you check it's voltage.
[ May 11, 2003: Message edited by: dmorris1200 ]</p>
BUILT FORD TOUGH
Old 05-11-2003, 11:48 AM
horvath's Avatar
Post
Thanks, guys ... I thought those numbers seemed off!
I just went out ... turned on the headlights for a minute ... checked the battery with an analog tester ... got 12 Volts at the battery and the same at the alternator -- my dash gauge was reading like 11.5.
Then I started the engine ... battery read about 14.5 ... alternator read about 14.5 ... dash gauge looked like 15.75
Obviously the dash gauge is off ... but how are the numbers from the meter? 12 Volts with the engine off and 14.5 Volts with the engine running -- is that cool?
Thanks again.
Alan
Old 05-18-2003, 12:06 PM
blockhead's Avatar
Post
That battery reading is still too low. 12V is just about flat. Use a digital meter to get a more accurate reading.
Old 05-18-2003, 09:48 PM
horvath's Avatar
Post
Thanks, blockhead.
I bought a digital meter and got 12.5, engine off ... 14.5 engine running/headlights on.
I think my alternator and/or regulator is going though ... I'm going to install a new one tomorrow and see what readings I get.
Alan Horvath
Old 05-19-2003, 03:49 PM
horvath's Avatar
Post
Bad alternator.
I took the truck to an alternator guy today ... it was cranking 15 volts! He sold me a rebuilt alternator, I took it home and installed it and my voltage readings are perfecto! Even my new dash gauge reads correctly.
My headlights had a slight flicker in them, too ... that's gone as well.
Sigh ... what a relief!
Alan Horvath
