Voltage reg. bypass - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2011, 07:17 AM
itsandre's Avatar
Voltage reg. bypass
Working on the final details of this engine transplant in my 62 Impala.
Two part question. I am converting the generator to an 3 wire internaly reg alternator. What to I do with the wirering at the old external
voltage regulator and generator? What is the best way to wire the alternator? So far the two big red wires I went direct to the battery and the small brown one will go to my voltage gage. Is this correct?
Second question, where do I pick up 12vdc to feed the HEI. Do I pick it up from the starter solinoid like it was with the old I235 point system?
Old 03-25-2011, 08:54 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Check the knowledge base http://www.hotrodders.com/kb/search?...m%2Fkb%2F#1506
Everything you'll need to know & what you need is there.
Rich
Old 03-25-2011, 05:27 PM
EOD Guy's Avatar
This is how I did mine to eliminate the external reg. My 12v feed comes from the ing switch.
Bypass vs Non-Bypass Oil Filter Adapter smokey626 Engine 53 05-20-2014 01:33 PM
ABS Bypass 123pugsy Electrical 14 08-02-2008 03:49 PM
Msd bypass wayneo Electrical 5 10-23-2007 06:10 PM
EGR Bypass HELP bigjoey71 Engine 4 12-21-2004 05:42 PM
Bypass REKRAP Engine 3 12-07-2004 06:15 PM
