Voltage regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2007, 03:17 PM
Voltage regulator
Is it O.K. to put my voltage reg. under the seat with the rest of my electric parts or will it create a heat sink?
Old 04-01-2007, 04:46 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Yes but.
You will need to increase the wire size of the main BATTERY wire at least (1) size due to the increased length.
Electronic regulators may have a heat sink (Aluminum fins etc.) that helps cool the solid state device that regulates the current going to the battery.
This may require a small fan to keep the air moving around the regulator.
vicrod
Old 04-01-2007, 08:32 PM
Well that's out. I don't have any room under the seat for a fan.
Old 04-02-2007, 10:12 AM
vicrod's Avatar
life is a ride
See attachment for small fans.
Or
You could make a larger heat sink with a piece of aluminum plate about 10"x10"X1/4 " thick . The heat sink on the regulator must be thermally contacting the plate. Use thermal grease (Rat Shack) between the regulator and the plate.
Mount the plate on spacers so that heat will dissipate from both surfaces.
vicrod
Old 04-04-2007, 03:40 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
You can use a Muffin Fan From a Computer MPU or case Cooling, (about 6 x 6 by 1 inch thick) .
Provides very good cooling, and MOST are 12 VDC..and cheap at rat shak or FRY's like $6.95..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
voltage regulator is buzzing orian Electrical 17 04-12-2006 07:13 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
voltage regulator 1bighawg Electrical 2 01-29-2004 06:47 PM
Electrical Short, Possible Voltage Regulator Claude Electrical 2 06-21-2003 01:13 AM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
