Voltage regulator wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2009, 09:24 AM
Mertz's Avatar
I was working on my 66 Catlaina and got the #4 wire from the voltage regulator struck in the carb return spring. While trying to get it loose it came disconnected and I can't find where it goes. It is a long light wire still connected to the 4 terminal on the regulator. The voltage reads just above 12v on my voltmeter with the engine running.
Old 09-08-2009, 04:58 PM
T-bucket23's Avatar
Wiki Edits: 26
My Diagram shows it on 1 side of the generator light. Shows it as a brown wire but on a different model so the color may not be correct
Chet
Old 09-09-2009, 05:34 PM
Mertz's Avatar
After some additional research that is what I found too.
Thanks for the help
Voltage drop. Please help. 77FIRE Electrical 15 05-23-2009 04:03 AM
Voltage Drop across Pressure Sender NovaSS350 Electrical 2 10-21-2008 07:50 PM
Just a Dead Battery? 1quiknova Electrical 7 06-07-2006 07:04 PM
427 or 454? frankenvette Engine 50 06-05-2005 10:12 PM
Electrical Short, Possible Voltage Regulator Claude Electrical 2 06-21-2003 01:13 AM
