Voltage sensing with 1 wire alt - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2005, 09:47 AM
bjr bjr is offline
New Member
I have a one wire self exciting alternator on my Willys Jeep. Can I ad a wire from the #2 terminal on the voltage regulator to my main junction block and get the benefit of voltage sensing without connecting terminal #1 through a diode to the ignition switch? Or will I have to change the regulator to a stock 3 wire regulator for voltage sensing to work at all. I need the voltage sensing feature because I run a snow plow in the winter which draws a lot power. Thanks Brian
Old 09-13-2005, 08:41 PM
docvette's Avatar
Wiki Edits: 12
Voltage sensing
Doc here,
By far and away, the easiest way to monitor voltage is to add an after market Volt meter which may be hooked between source and ground anywhere...
The attempt of trying to run the sense wire through the old regulator will not work simply because you have no field opening and closing the air gap contacts inside the relay to energize the sense circuit..
To attempt it directly should only yield you an "All On " or "All Off " indicator which would not be very helpful in monitoring the output..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-13-2005, 10:43 PM
New Member
I had a similiar situation with my one-wire. I ran a 16ga wire over to the junction from one of the terminals (I don't recall which one just try either, one of them works, and the other doesn't change anything from my experimenting). It didn't equate a 3-wire alternator's performance but it made a noticeable change under heavy load, helps boost the voltage. Good luck.
Old 09-14-2005, 04:54 AM
bjr bjr is offline
New Member
Read and understand the question
Originally Posted by docvette
Doc here,
Doc
Better re read the question. I don't think you have a clue what voltage sensing is all about. It has nothing to do with reading a volt meter. It's about the regulator in the alternator sensing the need for more output from a point closer to the power use.
Old 09-14-2005, 08:23 AM
docvette's Avatar
Wiki Edits: 12
Sorry
Doc here,
Sorry, mis read and confused the post with another I was answering about a totally different idea...I get distracted easy...shiny objects, long legs..blonde hair...
Go here , for all you need to know about Voltage sensing...BTW on the last page, covers the one wire operation, and their test results...
http://www.madelectrical.com/electri...esensing.shtml
Anyway, my bad, will have to slow up again when Reading the posts...sorry.
Doc
Innovations
Old 09-14-2005, 08:58 AM
bjr bjr is offline
New Member
still a question
Thanks for the good link lots of great info. My question is still not answered though. Will the self energizing voltage regulator in my one wire alternator, which has 2 spade terminals on it like a 3 wire alternator, work like a 3 wire alternator if hooked up so the #2 (red wire) is connected to the main junction block? Will it remote sense the loads at the main junction like a stock 3 wire alternator which does not have the self energizing feature? I hope this makes sense, it's kind of long winded and hard to explain.
Old 09-14-2005, 09:04 AM
New Member
Go back up and read my post. It's not a yes, it's like half a yes. You don't get exactly the performance of a 3-wire, but it'll be better than it is now.
Old 09-15-2005, 05:46 AM
bjr bjr is offline
New Member
thanks
Thank you all for the help.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
3 Wire Altenator Help. dsmith1279 Electrical 12 12-24-2004 07:42 PM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
