Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - voltage to tail lights vs brake lights?
Old 06-10-2006, 04:56 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
The "Duel Thingies" are Duel filament pads for the lamp filaments.
The voltage to each of the pads is NOT selective, it will be 12 volts No matter what..
What IS selective is the filament in the bulb for turn/brake Vs The filament in the bulb for Tails..If you put power to the bulb and ground, you'll note one "Pad" is brighter than the other..That one will be Brake/Turn..
The dimmer Filament will be the tails.
Doc
