I checked it with voltmeter at alternator and its reading 13-14 volts. NOW GET THIS!!! I had a B&M Megashifter that had a back-up light switch on it--this past winter I changed to a Gennie shifter which did not have the back-up light switch---so I taped the wires up and thought hell I never use the back-up lights anyway. But just yesterday I thought since I live in Pa I should have a way to turn them on because if the lights are on the car they must be functional. I put them on a toggle switch . Tonite the wife and I went out for a fish sandwich and somehow she (or her big purse must have hit the toggle (yeh its on her side of the car) because when I walked around the car I noticed the lights were on---turned them off and everything OK now---can't believe them 2 bulbs would pull that much juice---think I'll dissconect them again!
LOL. Never leave controls within reach of a woman! Just move the switch.
I have a toggle switch on my 4x4 with a red light in-line and the auxilary light's mounted backwards on the roll bar. Never had working back-up light's since I bought the truck. The auxilary light's work better than any back up's like having headlight's on the rear. Works great when 4 wheelin' in the dark.
If you put the backup lights back on does your voltage drop to 12. In a healthy electrical system a pair of backup lights will not effect the alternator output.
What is the output voltage with the headlights on. I am betting your regulator int the 1 wire is failing.
Artificial Intelligence is no match for Natural Stupidity Chet |
Could be a poor ground to the Voltmeter too,
Did you try turning them back on to see if the problem comes back. I am still not convinced that the backup lights are adding enough load to pull alternator voltage down to 12 volts. Makes no sense
Did you check the output at the alternator while the dash gauge was reading that low? I would........
| Cruise Control Compatibility with LED's? | cboy | Electrical | 44 | 10-01-2010 12:08 PM |
| A true 12 bolt? | pittbull7934 | Transmission - Rearend | 16 | 07-01-2009 08:34 AM |
| help please on a 67-69 rearend code PE | MusclecarBob | Transmission - Rearend | 10 | 06-16-2009 12:35 PM |
| 6 volts or 12 | cantspel | Electrical | 6 | 12-04-2004 04:08 PM |
| Converting Light System to 12 volts | JohnTN | Electrical | 2 | 12-04-2004 01:15 AM |
