voodoo cam install please help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-12-2010, 04:29 PM
sqzbox's Avatar
My pipes are my music
Originally Posted by eloc431962
Brian, All you need to do is after you have the dots lined up and the engine ready for the distributor, Then you will need to simply turn the engine over bring #1 back up "TOP" then install the distributor with the rotor pointing towards #1 on the distributer cap, Cole
Let me add to this while not to add to your confusion.
You put the chain and gear on dot to dot, turn the crank 360* and drop the dist. in. It doesn't matter where the rotor points as long as you follow the firing order from there on. Wherever the rotor points is #1 tower. Dropping the dist. in so the rotor points to #1 on the cap only applies if the cable's haven't been removed from the cap before the dist. was removed.
I prefer to get it ready for dist drop and leave it out for ease of installation of the engine without banging the dist. against the firewall and it's easier to access the top bell housing bolts. Then when you drop the dist in you can position the vacuum can for clearance between the firewall and the intake and carb. so you have room to rotate the dist. to set the initial timing.
Are you confused yet? I hope not. I'm just trying to simplify it as much as I can to help you out. It's really easy to do and after a couple of times it's a gimmie!
  #17 (permalink)
Old 12-12-2010, 04:32 PM
sqzbox's Avatar
  #18 (permalink)
Old 12-12-2010, 04:39 PM
sqzbox's Avatar
Originally Posted by T-bucket23
. After I posted it I said to my self, probably going to cause confusion
Self........., probably going to cause more confusion.
  #19 (permalink)
Old 12-12-2010, 04:56 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Heck now i am cornfused , Did i post something wrong ? Just trying to help the feller out and now i am .
Cole
  #20 (permalink)
Old 12-12-2010, 05:01 PM
sqzbox's Avatar
Naw. all post's are sound advise. I just feel as I am adding to the confusion as he's getting it from all directions at the same time. We haven't even talked about engauging the oil pump drive shaft yet.
  #21 (permalink)
Old 12-12-2010, 05:09 PM
eloc431962's Avatar
Wiki Edits: 37
I know Sqz, Just messing with you , The OP needs to be walked through these thing's as he said he is a rookie with this stuff, So i hope he get's it about the oil pump shaft. I hope he see's this and ask us about it cause i am not real sure he know's about it. And you when you get so many $ in something you want it right.
Cole
  #22 (permalink)
Old 12-12-2010, 06:28 PM
havin fun
chet, i'll try to forget it but now i'm worried. whats the matter with you man? dont you know you cant throw smart stuff at us not so smart people lol just kiddding thanks for the input and i think i understand what you meant.
brian
  #23 (permalink)
Old 12-12-2010, 06:34 PM
havin fun
ok guys what about the oil shaft lololol i installed the oil pump with the extension on it. once i get ready for the dizzy i orient it to slide into the grove on the oil pump rod and i'm good to go right? ya $ in this and i'm nervous lol
also anybody have any info on that gasket i mentioned and pictures in the first post?
thanks guys you all rock, help with humor lol
brian
  #24 (permalink)
Old 12-12-2010, 09:25 PM
NOlowrider's Avatar
US Navy-Retired
No. You orient the oil pump to the dist. Not sure it that is what you meant to say, if it is I am sorry. You align the oil pump shaft to the dist, not the dist to the oil pump. You install the dist at TDC, then you may have to take a long screwdriver and turn the oil pump shaft to where it will align with the dist. So it will sit flush with the intake manifold.
Much easier to do this before you drop the motor in the car.
  #25 (permalink)
Old 12-12-2010, 11:32 PM
sqzbox's Avatar
Originally Posted by NOlowrider
No. You orient the oil pump to the dist. Not sure it that is what you meant to say, if it is I am sorry. You align the oil pump shaft to the dist, not the dist to the oil pump. You install the dist at TDC, then you may have to take a long screwdriver and turn the oil pump shaft to where it will align with the dist. So it will sit flush with the intake manifold. Much easier to do this before you drop the motor in the car.
I cheat! I drop it in where the rotor points to where I want #1 at and I get a buddy to bump the engine over while I hold the dist. down till the dist. drops into the shaft groove. Bloop! it's done. bring it back to TDC comp. install cap and wires.
Shame on me, my bad? or just lazy?
  #26 (permalink)
Old 12-13-2010, 05:26 AM
havin fun
oh ok, ya i knew that one but thanks for the heads up anyway... and the scare lol
brian
  #27 (permalink)
Old 12-13-2010, 07:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
in the package there was another gasket that i dont see where it could go as it to big for anything i see. does anyone know what this gasket is for?
Sometimes there was a water pump rear cover gasket included in a rebuild gasket set, but I don't think that's what yours is. I'm kind of curious now, too...
  #28 (permalink)
Old 12-13-2010, 09:20 AM
havin fun
ya i'd hate to forget something " hey where d all my oil go" lol
  #29 (permalink)
Old 12-13-2010, 07:19 PM
ericnova72's Avatar
More for Less Racer
V8mazda, that round gasket isn't something that fits your 1st generation SBC, so no worries there. Maybe it is something for the second gen LT1/LT4, like the Optispark ignition cover gasket? Anyone out there know?? I've never worked on one.
  #30 (permalink)
Old 12-13-2010, 07:33 PM
havin fun
thanks eric for tip. my motor is an 86-88 350. thats what the #'s came back as anyway.
new cam install phanline6.6 Engine 13 03-10-2010 09:08 AM
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 05:36 PM
Delay between cam install and first start CuttyGMachine Engine 4 04-14-2008 07:34 PM
voodoo cam and head question camino_man Engine 0 07-09-2007 09:36 AM
cam install lilfrank2 Engine 5 01-29-2004 11:59 AM
