Vortec 1999 Rods
Compared the piston/rod weight from a '92 non-roller block (I mean totally- no spider bosses, etc.) and a '99 Vortec 5.7L powdered metal rod/piston.
'92 weighs 1410 grams, w/rings and nuts (and carbon), w/o bearings. '99 weighs 1320 grams, as above. Just comparing the caps, '99 was 10g lighter than the old style cap (130g to 140g). I suspect most of the difference is in the piston. With ARP bolts, about how much rpm are the powdered metal rods good for, using stock-weight pistons? How to they compare, strength-wise, to the "old" rods? Thanks, I'm trying to get up to speed w/this Vortec deal...
Thanks for that info.
I'll say this- the "new" rods' finish is far and away better than the pink-style rods. The forge lines are almost non existent, they're smooth as can be w/o any prep work. The area around the bolt head and nut bosses are very nicely contoured, the cap looks much better and is lighter, to boot. All in all, an improvement- as long as the strength's still there, and it would appear it is. Between the rods and the almost slipper skirt and thinner rings of the piston, you would almost think they were aftermarket parts. BTW, what's the ticket for plugging the 3/4" crank position sensor hole in the timing cover? |
peace Hog |
Competition Products still sells them re-sized with ARP's- NOW- $150 a set... what a freakin steal.
| Push rods for Vortec roller block | Flyin 57 Chevy | Engine | 3 | 01-07-2009 03:03 PM |
| Motorheads...Need help with Vortec style heads, can they just be swapped? | firstgear | Engine | 16 | 01-15-2007 12:02 AM |
| 5.7 rods in 400 | joefromcocomo | Engine | 9 | 02-05-2004 11:59 AM |
| new rods or old rods? | Blob | Engine | 12 | 02-03-2004 04:35 PM |
| longest rods in std deck 454 bbc?? | deuce_454 | Engine | 11 | 01-30-2004 10:06 AM |
