Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vortec 350 Build
Old 04-20-2012, 07:13 AM
dogwater dogwater is offline
78 Z28 Camaro
Last journal entry: 700r4 still running strong
5 or 6 yrs. ago popaular hotrodding mag. had a write up where they took a junkyard 4 bolt 350 roller short block an reused the pistons,rods,crank and put an EQ iron vortecs,but they had a custom grind cam from Comp cams. It made 447 hp.This is how I build my 350,except for the cam.If your interested I can get the mo. & yr.of the write up, Im sure its online.I do agree that an LS is the better way to go,but I would use an carb.intake.
