Vortec 350 cam,intake and carb choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 02:02 PM
31 five window
Last journal entry: grill and rear end
I have a factory stock 1998 350 Vortec long block which does not need to be rebuilt.I am putting it in my 31 model A coupe with a 700R4 and 9" rear with 29X12.50-15 tires and 3.50 gears.It will be mostly street but a little 1/4 mile track.I want to hear the lope when I idle in to the cruise night but also want best 1/4 mile performance and still be good for street driving. I have never fooled with a roller cam so I need some suggestions.Also not too much lift for the stock heads unless really needed for good performance. Fuel economy is not a big concern.Thanks in advance.
Old 07-28-2008, 06:08 AM
31 five window
Thanks Fbird. I did not mention a stall because I know it is needed with the cam swap and just did not think to mention it.I plan on running about a 2500 stall.
Old 07-28-2008, 06:17 AM
31 five window
I have another 98 Vortec 350 but the heads where changed to GM 10088113 aluminum and it has a Holley street dominator intake with a 750 Edelbrock carb. If I have to pull the heads anyway,which is the better of the 2 on a stock 98 Vortec bottom end?
Carb for the 350 sb? wretched ratchet Engine 18 02-20-2008 05:42 PM
What stall is needed for my TH350 / vortec 350 307malibu Transmission - Rearend 5 02-15-2008 03:55 PM
Carb selection help SLR_65 Engine 2 09-03-2007 05:44 PM
new 350 with a carb Gramps Engine 13 12-28-2006 04:49 PM
desperately seek opinions for carb choice txsfld Engine 53 11-22-2002 04:08 PM
