Vortec 350 gasket ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2007, 12:06 PM
Artemis Entreri's Avatar
Vortec 350 gasket ?
Building a vortec 350, I know I need special intake gaskets for a vortec style intake, do they require specific head gaskets also?
Old 09-15-2007, 12:28 PM
No! But different gaskets such as shim or composite/composition have differing thicknesses which affects compression ratio a little so keep up on their thicknesses. Thicker lowers compression, thinner raises it and improves what little squish/quench the factory circular dish piston provides. Shim gaskets like really flat and straight head and deck surfaces, composition gaskets are more tolerant of uneven surfaces.
Bogie
Old 09-15-2007, 12:31 PM
DoubleVision's Avatar
A standard SBC head gasket works fine. The intake gasket there are several versions, but if you use a aluminum intake such as buy Edelbrock, then get Edelbrock gaskets, or chances are it will not seal and will suck oil in the runners like there`s no tomorrow. I went through three pair before I got the Edelbrock gaskets and the problem was solved. With any aftermarket vortec intake don`t use the stocker replacement gaskets, When I was buying the third set I realized they get expensive fast.
ARE 305 and 350 VORTEC HEADS SAME badriand Engine 39 04-06-2011 09:40 AM
Singh's Grooves in Ported & Milled vortec heads on stock 350 automotive breath Engine 204 01-31-2007 08:38 PM
sbc 350 Head Gasket question oregon chevelle Engine 1 04-24-2006 02:25 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 08:45 AM
1987 tbi to a 1997 350 sfi vortec g.b. Electrical 0 10-19-2003 06:32 PM
