vortec 350 tick - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2007, 10:36 PM
vortec 350 tick
my 98 vortec 350 fires up like a champ , compression is good , after it idles for few it gets a slight knock from what seems to be the upper rear part of the motor .
Old 05-10-2007, 12:28 AM
DoubleVision's Avatar
Is it a knock or a tick? A tick at startup is usually a lifter, the roller lifters installed in these engines are prone to startup tick, sometimes it goes away after warmup, sometimes it don`t. Get a can of seafoam from your local parts store, pour it in the oil, start the engine and let it idle for about 20 minutes, change the oil and filter. This usually eliminates lifter tick.
This is my guess being it`s common and you say it sounds as if it`s coming from the top end.
Old 05-10-2007, 01:06 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
does it go away after its hot? If so its most surely piston slap. GM uses very short skirts on their pistons to cut down on friction and it shows up as piston slap. Its not a big deal. My LT1 has had noticable slap since 60k and I'm over 100k now. I'm leaving for a 10,000 mile summer road trip and I have no doubts that its fine.
It sounds bad, but (if it is piston slap) don't worry about it unless it starts rapidly changing for the worse
ARE 305 and 350 VORTEC HEADS SAME badriand Engine 39 04-06-2011 08:40 AM
Singh's Grooves in Ported & Milled vortec heads on stock 350 automotive breath Engine 204 01-31-2007 07:38 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
1997 350 Vortec Questions bobfray Engine 6 11-28-2003 01:15 PM
vortec 350 wiring g.b. Electrical 1 10-26-2003 09:43 AM
