Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vortec 355 fuel injection question??
Old 11-01-2012, 11:41 AM
BogiesAnnex1 BogiesAnnex1 is offline
Originally Posted by abbazabba View Post
Hello,
I have a 5.7 350 vortec .30 over daily driver+occasional tow(less than 5 times a year)
with comp cams 08-300-8 (grind cs 262h-r12)
duration at .050 206(intake) and 210(exhaust)
Rebuilt the trans and just beefed it up a little.
I estimate I will be pushing between 325 hp and 350 hp.
Original mileage was 272,000
I am just finishing up the build and realized I did nothing with my fuel injection system. I "believe" I have a multi-port injection looks kind of like a spider legs.
Can I just clean this well and call it good?
Do I need to replace the whole system?
Are there any specific parts that you would recommend that I change or inspect?
Thanks for the input!
Just eliminate the problem >>> GM VORTEC CSFI to MPFI CONVERSION >>>.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
abbazabba (11-01-2012)
