Vortec 5.0 downsize to 4.3 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2013, 09:27 AM
Hey i have a 305 with busted crankshaft and would like to swap it out for a smaller mor economical V6. Will the engine mounts n electrical, tach, speedomiter oil pressure.. work or how much extra work is it?
Old 04-02-2013, 11:56 AM
Banned
it is NOT more economical to run a 4.3l v6 vortec.
Old 04-02-2013, 01:37 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
A 4.8 LS is
Old 04-03-2013, 10:13 AM
In a fullsize GM truck, the L35 4.3 would only be more fuel effecient on the highway MAYBE.
200hp/260 lb/ft torque for the L35 4.3
230hp/285 lb/ft torque for the L30 305
I know that both use the single cat, y pipe arrangement with 3 precat O2 sensors and 1 aftercat O2 sensor.
The PCM's are the same, just need to be reflashed with the proper V6 calibration.
Be sure to use a V6 TC or the truck will be more of a dog. The V6 uses teh DBLF higher stall TC than the V8's.
You would need a V6 fan shroud. Trans will work, driveshaft is the same.
The V8 harness will work if you swap out the big connector that plugs into the fuel distribution block on top of the intake manifold. MAF is the same,
Throttle body is different between V8 and V6.
But honestly, I would find another 305. The 4.8 is a good idea, but off idle torque is lacking, but they pull great after 4000rpm.
peace
Hog
Old 04-03-2013, 11:06 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
The 5.0L isn't really that bad on gas for a truck. I had one in a 3/4 ton ex-cab/sb with a 4l60e and 3.73s through a 14bolt sf. Still got 15 mpg in city and cracked 20 on the freeway. Just yanked it with 250,000k on it (still running) to go in my 1984 Caprice. I have 5.7L vortec with an F-body LT1 cam that's going in it's place. Find another 5.0L or step up to the 5.7L. The best gas mileage improvement you'll see with these trucks is good control of your right foot.
4.3, 5.0, chev, crankshaft, engines
1998 350 Vortec Swap to 2000 454 vortec Bobbydnovaman Engine 4 12-19-2012 11:19 PM
can I downsize caliper retiredblue Suspension - Brakes - Steering 6 06-12-2011 08:22 PM
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 03:17 PM
Downsize carburetor Gordie T Hotrodding Basics 5 12-14-2009 04:24 PM
Need to downsize from my 750vac sec Holley. Want your choice of carb and why! club327 Engine 20 02-05-2006 10:27 PM
