vortec cam selection, custom grind?
ok, i was reading through this build that i've read a thousand times cause it's exactly where i want to go with my build (http://www.popularhotrodding.com/eng...manifold.html). they use a cam described as follows on the 2nd and 5th page, "Hydraulic roller cam COMP 12-000-8 custom 108 LCA, 4 deg. adv. $272.75". If i order that part number from summit will i get the same cam or do i actually have to specify what i want? Also would this still be the best cam for my build?
my setup: -'98 vortec 2 bolt, just a clean up mill -906's w/CCA-26918-16 springs, just a clean up mill -summit hyp +6cc pistions (9.6/1 with 64cc's) -pushrods/SUM-G6406, roller lifters/SUM-HT214 (mine were shot) -factory crank and rods. -factory press in rocker arm studs 1.5rr -4150 650dp mech. -proffesional products crosswinds intake. -3.90 rear end -iroc t5 -2300lbs '84 rx-7 thank you for your time and patience |
The link didn't take me anywhere. Are you talking about the "Sledgehammer" build? The best way is to order that through comp directly.
The cam in the build up used the EQ vortec replacement heads. They also used 1.6 rockers. They listed the lift as .565 and listed the duration as 224/224 @ .050. If that is correct they used XFI exhaust roller hydraulic lobes. The lobe number is 3035.
i seached for that cam (292H) on summit and all i could find was flat tappets, is there a roller version of this cam or something close in a hyd roller? i just don't know that much about cams yet. A decent price would be wonderfull as well
, i was hopping to stay (well) under 300$ for the cam alone.
how about any of these?
-GM Performance 12565308 -COMP Cams 07-306-8 -Edelbrock 2201 -EDL-2204 / i think i like this one, but, i still dont understand completely. could someone explain the what lobe seperation would be best for my build?? should i jump up compression from 9.6-1 with factory heads? Last edited by slate84; 02-03-2009 at 09:55 PM. |
Generally a different LSA on the same lobe profiles will produce these results:
Narrower: rougher idle, stronger mid-range, lower vacuum signal, worse milage Wider: smoother idel, broader torque curve (though lower), stronger vacuum signal, better milage larger bore/stroke ratios usually run better with a slightly wider LSA. Better flowing heads usually like a wider LSA. From what I have seen Vortec's like between a 105-108 LSA in most cases, but that may not be suitable on the street, nor with the wide split that a lot of dual pattern camshafts now have. For that reason I'll usually take an Isky over a Crane or a Comp cam- their shelf cams are closer to a single pattern (many of them are single patterns) and they run narrower LSA's. Overlap is closely related to LSA and is a result of cam durations and LSA. for street purposes I'd try to keep the overlap below 75º. Even that is a LOT for a daily driven engine. In most cases people are happiest with overlap values between 55-65 on the street. |
That is a custom ground Competition Cam. You really need to order that through them. And make sure you get the cam that is setup for the factory roller block. They're set up for a retainer plate.
What are you doing as far as headers and an exhaust system ? That will help determine your lsa. |
i'll be running 1 5/8 what i call, half long tubes. then purple hornies. i understand what each measurment is, but i just don't have enough knowledge to figure out how one effects another.
is the EDL-2204 cam a good one? it looks like its well balanced. i would care if the power didn't come on till a little later to since its a t5 with a 3.90 rear end in a 2300lbs car. traction through the 13" rims is going to be a ******. |
| SBC roller cam selection | 307malibu | Engine | 5 | 12-15-2007 09:53 AM |
| Cam selection for Vortec Chevy 383 | mytruckownsit | Engine | 7 | 06-14-2006 07:16 AM |
| vortec cam upgrade | Sudden Psycho 31 | Engine | 2 | 05-03-2004 10:23 PM |
| Cam Selection on Blown BBC | gt2betubbed | Engine | 9 | 06-03-2003 02:23 PM |
| CAM SELECTION HELP | 383stroker | Engine | 10 | 05-15-2003 12:38 PM |
