Vortec compatability issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2010, 06:36 PM
i recently got a whole vortec block complete with cam crank rods pistons lifters etc.. i am wondering if i can put 94 heads on this block with tbi and it run good and is it a roller cam? i have not picked it up yet
Old 04-25-2010, 12:39 AM
casting number
If you had casting number it would help. What year is the vortec? Alot of guys use vortec heads on older blocks. haven't heard non vortecs on a vortec though. Don't see why it wouldn't work. I can tell you if for give me casting number off of it.
Old 04-25-2010, 10:13 AM
i havent picked the block up yet. the only difference in the vortec heads that i know of are the intake bolt angles and combustion chamber design. i will post the numbers soon
Old 04-25-2010, 10:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The block (as long as it's a Gen I) will accept the '94 TBI heads.
The TBI cam might be enough different than the Vortec ('96-up) engine's roller cam that the original TBI ECM will not be able to compensate for it. If that's the case, you'll need to swap the cams. Hopefully the TBI engine had a OEM roller.
Be aware some truck/SUV engines were designated "Vortec" but were not THE '96- up Vortec engine that is commonly referred to.
Vortec Engine Swap Problems 5700 350 capps Engine 22 01-28-2016 12:06 AM
change a 1997 5.7 vortec to TBI ?For propane purposes oakman Engine 7 04-24-2010 10:04 PM
305 vortec heads vs 350 vortec rimracers Engine 6 04-02-2007 08:41 PM
Vortec Head Questions 78novaman Engine 23 06-09-2006 01:03 PM
a question about vortec 454s notmrgoodwrench Engine 4 02-23-2003 08:02 AM
