-   -   vortec conversion ? (http://www.hotrodders.com/forum/vortec-conversion-51484.html)
slim69 11-08-2004 09:10 PM
vortec conversion ?
I'm swapping an early style 350 for a 97 truck block vortec in my 49 ford coupe.
What alt. bracket do I need for v belt drive on the right side with a long style water pump.
I am also installing a zz4 roller cam with .494/.509 lift onstock heads. spec articles say modify the valve springs and seals. Two of my friends are running that cam with no problems. Are they just lucky. Car is a street cruiser only.
thanks
MI2600 11-08-2004 09:40 PM
1 Attachment(s)
Unless there is some difference between the Vortec and the standard engine, you should use one of these type brackets.
