vortec conversion ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2004, 08:10 PM
vortec conversion ?
I'm swapping an early style 350 for a 97 truck block vortec in my 49 ford coupe.
What alt. bracket do I need for v belt drive on the right side with a long style water pump.
I am also installing a zz4 roller cam with .494/.509 lift onstock heads. spec articles say modify the valve springs and seals. Two of my friends are running that cam with no problems. Are they just lucky. Car is a street cruiser only.
thanks
Old 11-08-2004, 08:40 PM
MI2600's Avatar
Member# 3287
Unless there is some difference between the Vortec and the standard engine, you should use one of these type brackets.
