I'm 90% sure that the 305 vortecs have the typical, tiny valves. They flow a lot less, but not sure if its because the ports are different, or if its just the valves.
For the extra 50 bucks it is SO worth it to get the 350 heads. To get 305 heads modified for larger valves and get them to flow like the 350s, you'll spend thousands. Plus, the small 305 chambers means you'll have to run dished pistons which will ruin efficiency and quench. Edit: Nevermind... I just noticed you're looking at a 5.0 engine... I was replying as if it were a 350. |
350's heads
I agree completely theat the 350's are the better ones by far... The trouble is that he's outta them right now but he has 4 96-99 vortec 5000's (cores), and also 2 LS1's I just got another 400 SBC today, with the deepest dish top in the pistons I've ever seen... I was told the motor had 47000 miles on it and dropped a valve in the # 1 hole. You can see the piston is all dinged up and a piece of the ring lad in broke off. I was just thinkin of builtin a mild torque motor outta this one to pu in my dually.... just basic cam prolly 254 or 268, or mabey one of the extreme 4x4 lines. I'd like to re-used the stock pistons and sdt bore cuz the cyl walls are in great shape, just put a set of rings and bearings in it with that cam...
This is where the trouble comes in The new 400 i got was a short block(no heads, balance or flexplate). So I need heads, and even thought the one a asked about are 305 heads, thier still "VORTECS", Whick will definitely make more power then some old smoggers I got laying around.. When it comes to the heads, I thing theyr'e listed on mortec as 58cc chamber with 194/150 valves, but it doesn't say runner size... Anybody know??? ALSO I was brousing through ebay the other day and a guy had a set of an Astrovan 305 for sale, 059 casting.... What baffled me was that they had the traditional chamber style.... The plug boss was out to the middle as it should be, but the chamber wasn't "heart/kidney shaped"... you guys know any thing of this?? I thought all vortecs had the heart shaped chamber??? One last thing... I'd say the pistons in this motor are atleast 30cc dish, what kinda CR would that give me on a 400 with 58cc chamber heads??? |
Here's a good CR chart for the factory style 400 piston.
http://www.northernautoparts.com/Pro...tModelId=15104 |
L30
230hp 285 lb/ft torque L31 255hp 330 lb/ft torque The L30 still uses a raised runner port, and I have been told that they are THE Stock 305 head to have. The L31's do flow more. peace Hog |
have you ever been in a truck with the L30 305? i must say their pretty damn stout for what they are. on a 305 those heads do fine, they have 1.84-1.5 valves & 58cc chambers. i don't know what they would do on a 400.
Bogie All "modern" small blocks use powdered metal rods and cast hypereutectic pistons. I'm not aware of any factory forged cranks being used with one piece seals, that includes the LT1 and LT4. Vortec blocks from mid 95 to end of production have at least the provisions for a roller cam. This makes them attractive from the stand point that they are a lot less expensive to build as a roller engine even if they originally had a flat tappet cam than are blocks never made for a roller cam. This makes them attractive to engine builders. Bogie |
"Vortec" is just a trademarked "marketing" name for a GM motor....
that last/latest inline SUV 4.2L six is a "Vortec" motor.... the very early inline six was named a "Blue Flame" motor in the 54' vette to make it sound more sexy since a V8 wasn't offered.... LOL, Ford "Cobrajet" motor, I'm thinking a snake with a flame shooting out of his butt hole????? only the spec's of a particular head model # can tell you the good/bad/ugly |
| 383 Recipe | Sweet Lu | Engine | 9 | 10-20-2007 12:01 AM |
| Starting on first engine soon, lots of questions | OneBeast | Engine | 6 | 09-12-2007 07:27 PM |
| Engine | G-mac | Engine | 7 | 03-28-2006 10:21 AM |
| Engine Choice, Please Help | savman1 | Engine | 1 | 01-12-2006 09:36 PM |
| 327 question | adam15425 | Engine | 80 | 10-13-2004 09:22 PM |
