vortec engine in 85 monte - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2002, 05:58 PM
New Member
Post vortec engine in 85 monte
if i pulled all the computer stuff off a 99 5.7 vortec engine what would i have to go through to put it in? could i carburate it to make the prosess easier or what? I know some about engines but not about swapping them so anyhelp would be appreciated. thanks
Old 08-28-2002, 06:03 PM
Post
what are you putting it in and you probably have to carberate it without the cpu.
Old 08-28-2002, 06:19 PM
New Member
Post
I am putting it in a 85 monte carlo ss
Old 08-28-2002, 06:47 PM
Last journal entry: Doors
Post
It may not work since I believe the 85 monte carlo has a 305 in it. The 305's have 54'cc cumbutsion chambers. A 64'cc vortec cumbution chamber would give you a terrible compresion ratio, I think i calculated it once and it would be bellow 8 to 1 that low of an compresion ratio would give you bad power and bad economy. To make matters worse the 305 comes with a thin gasket so, that cancles out the option of putting a thin gasket on to raise compression ratio
Old 08-28-2002, 06:49 PM
Post
Wops!! I seem to have read it wrong, i thought u wanted to put the hole heads on. If your not using the heads wanna sell them??
Old 08-28-2002, 07:24 PM
New Member
Post
i think ill be using the heads but to clear things up i wanna swap the vortec for my 305
Old 08-28-2002, 07:25 PM
Post
you want to replace the hole engine or just the heads with the vortec
Old 08-28-2002, 07:27 PM
E.T. divided by $ spent= Speed
Post
Are you from montecarloss.com????If not go there theres a guy doin the same thing,saw the question the other day.
Old 08-28-2002, 07:40 PM
Post
Guess that was your question on there.Stick around here its a cooler place.
Old 08-29-2002, 06:46 AM
New Member
Post
haha yeah it is me, but yeah i do wanna use the whole vortec engine and replace my 305 and i was wondering how to do this
Old 08-29-2002, 06:56 AM
Stinkin_V8's Avatar
Suburbanite Member
Post
It would be easier to just carb the vortec engine when you move it over to the Monte. You could yank the whole wiring harness and ECM and keep the fuel injection, though. A lot of the aftermarket companies sell intake manifolds that use the vortec head bolt pattern.
When life hands you lemons, ask for tequila and salt
Old 08-29-2002, 08:46 AM
New Member
Post
Thanks, i would most likley end up carburating it
