Vortec Engine Help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-23-2010, 12:00 PM
Elkyblack's Avatar
Originally Posted by turbolover
a smaller cam would produce better torque and not give up much at all in terms of hp. The cam recommended will sound nicer but dropping about 5-10 degrees will save you gas and gain you performance for the street.
Which cam do you recommend Turbolover? What kinda torque gains are we talking. I love the sound of the cam recommended, I would be willing to sacrifice sound a little if I will notice a significant amount torque and hp gains. I really would prefer the best of both world.
  #17 (permalink)
Old 09-23-2010, 12:05 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Choppy idle, strong low and midrange performance. 2,500+ stall. Easier on the wallet too.
http://www.summitracing.com/parts/HRS-180305-08/
  #18 (permalink)
Old 09-23-2010, 12:16 PM
Elkyblack's Avatar
Beetle Do you think this would be a better cam than the cam recommended by Tech? Do you have any sound clips? Just so you guys know I really do appreciate all of this. Im sort of a newb, I mean to actually putting together my own combos. I've had many motor built from bad *** 496's to 355's but It was always me dropping it off to a builder and them doing it. This time Im going to attempt this myself . So any and all advice is greatly appreciated. I have my pad and pen taking notes.
  #19 (permalink)
Old 09-23-2010, 12:39 PM
I would avoid that Howards cam. Large duration, low lift... Not really an ideal combo.
If you want a choppy lope have the LSA narrowed up a bit, it will increase midrange torque AND give you a choppier idle.
I think the XE 276 on a 106-108 LSA would be a better match. A 106 would provide a choppier idle but will be harder to tune. A 108 is a good compromise IMO. Have it ground on a 102 ICL.
You'd probably pick up about 20 ftlb in the RPM range you drive in with this cam VS the one recommended by TI.
With a 108 LSA the smaller cam will sound almost identical to the other one recommended, the overlap values are very close.
There are many other cams out there too, this is just a quick example of what I would look for.
  #20 (permalink)
Old 09-23-2010, 12:47 PM
Elkyblack's Avatar
I would avoid that howards cam. Large duration, low lift... Not really an ideal combo.
This might be a crazy question
If this was your motor and you wanted to get the best performance out of it what cam would you go with?
  #21 (permalink)
Old 09-23-2010, 01:20 PM
Good point. Although, vortecs really don't flow well over .50" lift. So a .480 cam would okay if you wanted good torque and performance. For max performance, around .50" lift would be better.
Published vortec Flow numbers.
0.100 70/49
0.200 139/105
0.300 190/137
0.400 227/151
0.500 239/160
0.600 229/162
  #22 (permalink)
Old 09-23-2010, 02:44 PM
0.100 70/49
0.200 139/105
0.300 190/137
0.400 227/151
0.500 239/160
0.600 229/162
That all depends on the valve job...
Those flow numbers can vary by 10% based off of a valve job.
  #23 (permalink)
Old 09-23-2010, 02:56 PM
Makes sense. Good call.
  #24 (permalink)
techinspector1's Avatar
Wiki Edits: 326
The nice thing about the DynoSim is that you can change cam timing around and take a look at the results pretty quickly. The XE276 would be a flat tappet grind. The same grind for this motor (roller cam) would be a XR276HR. If we change the seat to seat intake opening from 32 to 36 and the seat to seat intake closing from 64 to 60, we have an intake centerline of 102 instead of 106 and an LSA of 108 instead of 110.
Now, we have these timing figures....
Seat to seat 36/60/75/27
0.050" tappet lift 10/34/49/1
Intake centerline 102
Exhaust centerline 114
Lobe separation angle 108
Seat to seat duration 276/282
0.050" tappet lift duration 224/230
Valve lift 0.502"/0.510"
As turbolover predicted, low rpm torque increases and high rpm hp decreases with the tighter LSA. The break-over point is 4000 rpm. Power builds quickly at the bottom, then peters out past 4000. This grind would make a better daily driver though, in my opinion, than the cam timing I originally used in the DynoSim if you were using a converter that tightened up low enough in the rpm range to take advantage of the torque at low rpm's.
RPM HP TQ
2000 140 367
2500 177 372
3000 226 396
3500 284 426
4000 335 440
4500 380 443
5000 412 433
5500 426 407
6000 418 366
6500 369 298
Peak volumetric efficiency 95.7% @5000
Peak BMEP 188.0 @4500
Here's the first pull to compare....
RPM HP TQ
2000 133 350
2500 169 356
3000 218 381
3500 278 417
4000 334 439
4500 383 450
5000 417 438
5500 441 421
6000 445 390
6500 417 337
Peak volumetric efficiency 99.0% @5000
Peak BMEP 189.5 @4500
  #25 (permalink)
Old 09-23-2010, 03:10 PM
As turbolover predicted, low rpm torque increases and high rpm hp decreases with the tighter LSA. The break-over point is 4000 rpm. Power builds quickly at the bottom, then peters out past 4000. This grind would make a better daily driver though, in my opinion, than the cam timing I originally used in the DynoSim.
RPM HP TQ
2000 140 367
2500 177 372
3000 226 396
3500 284 426
4000 335 440
4500 380 443
5000 412 433
5500 426 407
6000 418 366
6500 369 298
RPM HP TQ
2000 133 350
2500 169 356
3000 218 381
3500 278 417
4000 334 439
4500 383 450
5000 417 438
5500 441 421
6000 445 390
6500 417 337
I was meaning the XR-HR series- That's a good catch, thanks TI.
I tried to stay with the same cam series you used, really its not a bad cam line at all.
I knew your selection would win up top, but how often does a daily driver go over 4,000 RPM? when I'm on the interstate I like an engine where I just need to put the slightest amount of pressure on the accelerator and I'm at the speed I want, smooth midrange (2000-5000) torque. On the back country roads its a different story.
  #26 (permalink)
Old 09-23-2010, 03:20 PM
Elkyblack's Avatar
RPM HP TQ
2000 140 367
2500 177 372
3000 226 396
3500 284 426
4000 335 440
4500 380 443
5000 412 433
5500 426 407
6000 418 366
6500 369 298
RPM HP TQ
2000 133 350
2500 169 356
3000 218 381
3500 278 417
4000 334 439
4500 383 450
5000 417 438
5500 441 421
6000 445 390
6500 417 337
Now were these numbers done with the motor now being a 383 or does that even matter?
  #27 (permalink)
Old 09-23-2010, 03:36 PM
I presume that is for 350ci, and I think its a hair optimistic.
making it a 383 will make a difference, if you have the crank I would definitely go for it. From a dead stop that thing may end up being a tire burner.
  #28 (permalink)
Old 11-08-2010, 09:53 PM
Elkyblack's Avatar
RPM HP TQ
2000 140 367
2500 177 372
3000 226 396
3500 284 426
4000 335 440
4500 380 443
5000 412 433
5500 426 407
6000 418 366
6500 369 298
RPM HP TQ
2000 133 350
2500 169 356
3000 218 381
3500 278 417
4000 334 439
4500 383 450
5000 417 438
5500 441 421
6000 445 390
6500 417 337
Tech, I know this thread is an old one, but I have gotten everything on the list that you mentioned except cam, but was kinda wondering what kind of power could I expect with the roller 283 thumper cam. What are your thoughts on these cams.
  #29 (permalink)
Old 11-09-2010, 08:46 AM
Thumpr cams are ground for sound, not so much for performance, although it'll perform decent. The cam specs he has listed will produce a lumpy sound. If you want it even choppier, get it ground on a 106 LSA.
  #30 (permalink)
Old 11-09-2010, 08:51 AM
Elkyblack's Avatar
Are you referring to the xr276hr cam? And how would I get a custom grind?
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 08:35 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
Vortec engine upgrade gb709 Engine 0 08-18-2008 10:39 PM
327 question adam15425 Engine 80 10-13-2004 10:22 PM
