Vortec Engine Help - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-09-2010, 08:11 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Originally Posted by Elkyblack
Are you referring to the xr276hr cam? And how would I get a custom grind?
Yeah. Just call up comp cams and tell them you would like to order a custom grind. The xr276hr ground on a 108 LSA or 106 LSA. The tighter the LSA will have choppier idle and will produce less vacuum. I'm not sure if you're running power accessories. The tighter LSA will also have better bottom end and mid range performance. Top end will suffer as you see in the dyno sims Tech prepared.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
Vortec engine upgrade gb709 Engine 0 08-18-2008 09:39 PM
327 question adam15425 Engine 80 10-13-2004 09:22 PM
