Bore the block +0.030" and use these pistons. Cut the block decks for zero deck and use a 0.041" compressed gasket for 9.6:1 static compression ratio and 0.041" squish. http://www.kb-silvolite.com/kb_car/p...tails&P_id=155 http://www.summitracing.com/parts/FPP-1003/ The problem with using more lift with the stock L31 springs is that the bottom of the retainer crashes into the guide seal with lifts over (depending on whom you talk to) 0.430" to 0.450". There is more play than that, but you must leave some of it for a safety margin. Crane Cams makes a drop-in spring and retainer that requires no machine work and leaves the stock seal in place for a 0.640" max net lift capability. You won't be able to use that much lift though, because the tappets can drop down below the dogbones at lifts exeeding about 0.535" (not absolutely sure about this figure, but I think Cobalt has it and will probably correct me with the right figure). Also, sometimes the seal is not pushed fully onto the guide at the factory, so use a 1/2" socket to tap the seal home before assembling the springs onto the heads. http://cranecams.com/?show=browsePar...Number=10309-1 http://www.summitracing.com/parts/CRN-10309-1/ Spring description: O.D. 1.255" I.D. 0.870" Seat pressure 124# @1.750" installed height Open pressure 374# @1.150" Coil bind 1.100" Rate 409#/inch CompCams 08-432-8 hydraulic roller camshaft. Use the stock L31 roller lifters, dogbones and spider. http://www.summitracing.com/parts/CCA-08-432-8/ http://www.compcams.com/Company/CC/c...?csid=189&sb=0 Edelbrock 7116 RPM Vortec intake manifold mounting 750 carb of your choice, vacuum secondaries. http://www.summitracing.com/parts/EDL-7116/ 1 5/8" long tube headers RPM HP TQ 2000 133 350 2500 169 356 3000 218 381 3500 278 417 4000 334 439 4500 383 450 5000 417 438 5500 441 421 6000 445 390 6500 417 337 Peak volumetric efficiency 99.0% @5000 Peak BMEP 189.5 @4500 Use manual trans or 2500 stall converter with auto trans. Use 3.73 or shorter gear. |
I agree with everything Techinspector said, but I'd go one step smaller on the cam. Stock Vortec heads don't see much gain after about 220-225 intake duration (.050" numbers)- especially on street engines.
change the pistons to ones with a different compression height like: http://www.summitracing.com/parts/UE...-030/?rtype=10 Your compression will remain around 9.6:1 |
I had mine, 3.75 internal balance Eagle crank, checked out by a machine shop and the journals were a hair on the big side. That was ok because my rods were a hair on the big side after resizing. All bearing clearance were between .0018 - .002. The problem I ran into was I didn't know you need narrow bearings. I can't recall the part number, but I believe they were H series, or N series (?)( Clevite bearings. Eagle cranks have a little extra material, or a bevel / flange where the journals meet the throws. This gives them extra strength over stock cranks. |
Although, you'll have to grind the rods and possibly the oil pan rails so the 3.75 crank will live comfortably. I would recommend getting a small base camshaft to avoid having to grind on your rods or get some 5.7 eagle rods with have more shoulder clearance. You'll still more than likely have to kiss the eagle rod shoulders to get the needed .05 clearance between the cam and rod shoulder. With the KB135-030 pistons and the block zero decked, you'll arrive at a 9.008 stack. To keep the squish within the .035 - .045 range you would need to go with a gasket no larger than .037". |
yup H series...http://www.competitionproducts.com/C.../products/738/ |
Thanks for all the input guys. So basically the combo Tech put together with the pistons Z recommended with the 383 crank should be a solid combo. What would the sound quality be with that cam Tech recommended, and what kinda power would this motor yield with this combo.
http://www.youtube.com/watch?v=V10Ks0_aXk8 Look in the previous post #2 for power. I would guess around 450 hp and 475 tq with the 383 setup. |
a smaller cam would produce better torque and not give up much at all in terms of hp. The cam recommended will sound nicer but dropping about 5-10 degrees will save you gas and gain you performance for the street.
| Pinging on 03 Chevy 5.3 Engine in Suburban | bry21317 | Engine | 42 | 10-02-2011 07:35 PM |
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| 1968-1969 olds 455 engine is this good and how can i id | 1968olds455HO | Engine | 5 | 09-02-2009 11:53 AM |
| Vortec engine upgrade | gb709 | Engine | 0 | 08-18-2008 09:39 PM |
| 327 question | adam15425 | Engine | 80 | 10-13-2004 09:22 PM |
