vortec engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2012, 04:43 PM
vortec engine swap
i have a 98 chevy with a vortec 350 i just blew up so i took a 350 out of a 88 but had to use the cam out of the vortec and now i cant get it timed right
Old 01-05-2012, 05:47 PM
Whoa, these are very different engines. The Vortec is all manged by the computer and has a completely different fuel injection system that shares nothing in common with the 88 TBI engine.
-The damper is completely different, the Vortec has provision to trigger a crankshaft position sensor in the timing cover the 88TBI does not.
- The engine timing covers are different the Vortec has a crankshaft position sensor, is made of plastic, uses a different selection of fasteners, etc.
- Moving up top, the heads are different and have a different intake bolt pattern than the 88, the earlier heads will not take the 98's intake.
- The cam is different the 98 uses a roller cam with quite a bit more timing than the 88's flat tappet.
- The distributor is different, the 98 takes all its instructions from the computer which is unique to it, the 88, while also computer operated, is using different sensors and different logic. The computer from one does not operate the other.
- Sensors and fuel injection is radically different, the computer from the 98 will not have anything the 88 can use if it still has TBI.
- The fuel system is way different, the 98 feeds about 60psi to the 88's 15 psi. The 98 doesn't use a regulator and bypass line but is switched on and off as needed to maintain pressure by the computer. The 88's pump is also under computer control but is on all the time and uses a regulated by-pass to maintain pressure.
- The 98's computer contols the transmission, taking a lot of data from the engine sensors. The 88 used a mechanically controlled earlier version of that transmission so the 88 engine does not have the necessary sensor data feeds.
So the question gets to how much modification, as you see above, has been done to support the 88 engine in the 98 chassis?
Bogie
vortec engine swap help Konman350 Hotrodding Basics 2 02-07-2011 08:31 PM
Swap out 5300 Vortec Engine & Tranny Ell Engine 1 12-18-2010 05:50 PM
vortec engine swap 620 dude Engine 4 07-10-2010 01:59 PM
1996 Vortec Engine Swap - need Help Adam Mclaughlin Engine 14 01-03-2005 09:56 AM
2000 Vortec Swap - Engine Won't Run - Vats? Adam Mclaughlin Electrical 3 03-22-2004 08:52 AM
