vortec engine swap help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2011, 07:43 PM
Hi, i have a 1980 GMC sierra 1500 with the stock 305. I am going to put a vortec 350 in it. what wires does the vortec need to run.
Old 02-06-2011, 07:52 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
Assuming you are taking a carbureted engine out and installing a fuel injected Vortec engine, you would need the complete wire harness, computer and all of the sensors.
If you are just going to run a carburetor, then nothing is different electrically other than needing to run an electric fuel pump since the Vortec block won't have provisions for a mechanical fuel pump.You'll also need to get the correct intake manifold and reuse your distributor.
Old 02-07-2011, 08:31 PM
thank you for the help. ill let you know how it goes.
Swap out 5300 Vortec Engine & Tranny Ell Engine 1 12-18-2010 05:50 PM
vortec engine swap 620 dude Engine 4 07-10-2010 01:59 PM
Vortec Engine Swap Problems 5700 350 capps Engine 21 04-06-2010 05:29 PM
1996 Vortec Engine Swap - need Help Adam Mclaughlin Engine 14 01-03-2005 09:56 AM
2000 Vortec Swap - Engine Won't Run - Vats? Adam Mclaughlin Electrical 3 03-22-2004 08:52 AM
