vortec exhaust ports - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2004, 11:10 AM
I have what I thought was a matched set of L31 vortec head (906 casting) that I was going to put on a 383.
I noticted that the exhast seats or different. One head's date code indicated it is a 2000 and it has a exhaust seat insert. The other head is a 1996 and it does not look like it has an insert.
Is this possible? Is there a diffenence in heads between years?
Thanks, Dave
Old 05-31-2004, 12:11 PM
BOBCRMAN@aol.com's Avatar
You will find minor differences not only in years but in the numerous production runs. Minor differences even in the same no. castings. What you see is possibly the seats fully cut at a different height in the casting (common). The seats could have been repaired on the production line (also common).
Have a good three angle valve job done on them, shorten the guide height, blend any sharp edges, smooth the short side port radius and run them.
Old 05-31-2004, 11:40 PM
I think some of the -906 heads that were destined for heavy-duty trucks were fitted with exhaust seat inserts by the factory.
Old 06-01-2004, 12:05 AM
can you take those bad exhaust seats out?
Old 06-01-2004, 12:14 AM
The seats aren't bad.
I thought I remembered reading what jimfulco said that some heavy duty trucks had inserts and that they did not flow as well.
Can anybody confirm that all heads with inserts are from heavy duty trucks and do not flow as well as heads without inserts?
Old 06-01-2004, 12:32 AM
Can you take out the inserts?
thanks
Old 06-01-2004, 03:23 AM
If you take them out, your valves won't have anywhere to seat. If they don't have smooth transitions to the exhaust ports, you might be able to fix them with a grinder.
