vortec fuel regulator bad or good?
I have two vehicles with the same symtoms one a 2000 gmc and the other a 99 gmc. both of these vehicles take extended cranks to start .both fuel pumps turn on with the first ignition start, I have been told that the fuel presure regulator is going bad or is bad ,how do you check them?. The 2000 is an external regulator on the fuel rail. and the 1999 is internal under the intake. anyone know how. thanks gb
the spider injectors, on 96+ are called "sfi" . they fire as each cyl needs fuel. there are 6 individual injectors inside the "injector block". they are in the 2 piece, aluminum lower and plastic upper manifolds. the "cpi" spider injectors are in the 93-95 2 piece, both aluminum, 4.3 manifolds. the cpi injector is basically a tbi injector inside a spider housing. it is on all the time. as in, each cyl is getting fuel all the time.
my 97 4.3 has had an idle psi of 52 since day one. i bought it new, and it has always run fine. has 14,500 miles on it now. and well over 300hp |
he never mentioned if it was a v-6 or v-8. yes, i know the differences between them. those fuel pressure specs i gave were directly from the factory service manual. yes, i know what the systems are and how they work. i work on them wayyyyyyyyy to much. not the best systems gm came up with (spider style that is)............also, the problems i've mentioned are ones that i've experienced first hand. done alot of v-6's too...........injectors in these systems are basically junk. gm has a service bulletin out on them outlining a replacement to a MFI setup, available at dealerships to retro fit vehicles with "spider" type injector systems. the tsb covers basically all versions of it that they produced. i'd have to look up the details to be 100% sure on that though, so that will give me something to do at work tomorrow. i'll post it here tomorrow night.
as far as your 4.3 producing "well over 300 hp" goes, what have you done to it to get it there? it ain't stock or chipped............stock isn't even close, and it would take one hell of alot more than just a chip..........and did you get the motor dynoed for this figure? is that number crankshaft hp, rear wheel hp, or just an estimate? just curious...................... |
i got the tsb as i promised, but i'm not going to post it. i really don't feel like scanning 21 pages to post them here!!! i'll relay any of the info if you like though...............also, the "spider style" systems, as i'll refer to them, were used until 2002 on certain applications. they are very common in vans and cabover trucks equipped with 5.7L (350's) engines. some vehicles have problems with them, some don't. just as i mentioned before though, not the best design in the world, and that's why gm changed it and went to more conventional design. once i get my new car built though, i'll run ya!!!
yeah, its a pretty crappy design.
as far as running me. sure, come on down but remember, if i was looking to be the fastest around. do you really thing i would pick a 4.3 to to it with . mid 12's will be just fine with me. |
yeah, i did..........nice project...........except you've got a few more pieces than mine.................don't make me add on juice............i'll do it...............i wonder if i can run faster while shooting nitrous? more oxygen ya know..........hahahahhaa
ok, the race is on !!! we'll put No2 bottles on our backs. and run(pun intended) heads up. LOL (they need some more/better smillies in here)
btw, i am putting a manifold like this one on my engine. |
| Vortec Engine Swap Problems 5700 350 | capps | Engine | 21 | 04-06-2010 05:29 PM |
| fuel cell installation | 19nova72 | Engine | 5 | 11-19-2004 04:36 PM |
| Any Good CamaroZ-28 Mechanics out there? Help!! No Start! | chevcamz28newbie | Engine | 10 | 07-12-2003 09:40 PM |
| Measuring Fuel Pressure | Waterhead | Engine | 7 | 06-20-2003 08:39 PM |
| Holley fuel injection with Vortec heads onna SBC. | Pappy | Engine | 3 | 06-06-2002 11:17 AM |
