Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vortec head conversion - EGR
Old 03-28-2009, 11:43 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Find someone with a sniffer. Some old shops have them for carb tuning. You can really clean up a tune that way.
Additional cam can clean up the NOx that an EGR would normally create, but the increased compression associated with larger cams kinda negates that. Plus larger cam often equals increased HC emissions.
I would personally keep the EGR if you can rig one up, but truly, emissions is largely in the tune. Many of us LT1 guys have gotten away with pretty hefty power numbers and still pass OBD2 emissions in CA. A common setup many of us have done is fully ported stock heads, ported intakes, cams in the 230 duration range, headers, and compression in the 10.5-11 range and with careful tuning it still passes CA emissions testing for 96 vehicles.
I would say focus on the tune first. Down the road if you want to continue cleaning it up then you can add EGR and other smog magic
