Vortec head conversion - EGR - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2009, 07:48 PM
I am going to be swapping some vortec heads onto my 76 C10 pickup in the next few months and I want to keep my EGR. I know there will be those who say just ditch the egr but I am wanting to eventually update most everything on the truck and pass emissions. We do not have a visual test, just the gas analyzer test. My question is this, how is the exhaust gas plumbed to the intake. I am aware that I will have to weld a pipe into my #5 or #7 header pipe. However, does that pipe run to the top or the bottom of the intake and if it is to the bottom of the intake, how does that work? Does there have to be a hole drilled through the heads or the block to run the pipe through? Any insight would be greatly appreciated. I have been searching on this for a few days but am coming up empty handed. By the way, the truck has been converted from carb to TBI so the intake I will get will have a place for an EGR.
Old 03-28-2009, 08:34 PM
I do intend to upgrade the cam. The one that I would like to use is the comp cams 12-262-4 with 262 intake/ 270 exhaust and at .050 has 218 intake/ 224 exhaust and the lift with 1.5 rockers is .464 intake and .470 exhaust and finally the LSA is 114 degrees. Is this enough to create the self- egr effect?
Old 03-28-2009, 08:52 PM
That is great news then. At least I do not have to worry about spending the money and figuring out how to plumb the gasses. I want one day to have my truck updated with modern systems for economy and power but still cut down on my emissions. Sure going to be an improvement over my "smog" engine now.
Old 03-28-2009, 08:53 PM
TBI will probably freak out with that cam
Old 03-28-2009, 08:55 PM
va4cqd I will have a custom chip done by Brian over at tbi chips. He is the one that suggested to use that cam with the vortecs.
Old 03-28-2009, 08:58 PM
what emissions requirements will the truck be tested to? as a 76 or the year the TBI is from?
Old 03-28-2009, 09:06 PM
It will be tested as the 76 but I am one of the few that wants to clean up the engine as much as possible.
Old 03-28-2009, 11:43 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Find someone with a sniffer. Some old shops have them for carb tuning. You can really clean up a tune that way.
Additional cam can clean up the NOx that an EGR would normally create, but the increased compression associated with larger cams kinda negates that. Plus larger cam often equals increased HC emissions.
I would personally keep the EGR if you can rig one up, but truly, emissions is largely in the tune. Many of us LT1 guys have gotten away with pretty hefty power numbers and still pass OBD2 emissions in CA. A common setup many of us have done is fully ported stock heads, ported intakes, cams in the 230 duration range, headers, and compression in the 10.5-11 range and with careful tuning it still passes CA emissions testing for 96 vehicles.
I would say focus on the tune first. Down the road if you want to continue cleaning it up then you can add EGR and other smog magic
Old 03-29-2009, 11:20 AM
Curtis, I have one question about the cam that basically serves as EGR and still keeping the EGR valve. If the cam lets in exhaust gasses, and then the egr adds in exhaust gasses, won't there be way too much? Or, will the cam just let in exhaust gasses at low speeds and not highway speeds where the EGR will kick in? Still just a slight bit cloudy on the subject. Also, what do you think the performance difference between the carb vortec intake w/out egr and the tbi vortec intake with egr would be?
Vortec head lift Q's maxpower_454 Engine 7 03-01-2009 07:21 AM
vortec head coolant sensor '71 Chevelle 307malibu Engine 20 10-13-2008 08:23 PM
best plugs for a vortec head? runn141 Engine 6 09-05-2008 02:15 PM
LT1 head to vortec head 46 chevy pickup Engine 4 08-30-2008 07:27 AM
Which vortec head is best? swoodard23 Engine 3 12-30-2007 05:19 AM
