Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - vortec head coolant sensor '71 Chevelle
Old 10-07-2008, 07:47 PM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
Originally Posted by 307malibu
Would it be possible to just get a sensor for a '97 silverado, like where the vortec motor was originally from? Or wouldn't that match up with the factory wiring (I'm fine with splicing in a different fitting, but I do want it to actually work good).
By the way, all I'm talking about is an "idiot light" setup. I don't have a fancy temp gauge in my base malibu.
Thanks for the help so far, guys!
Resistance values from a 1997, are way different from a 1971.
You need to use the stock sender from the 1971 application. This will work correctly with your dash 'light'/gauges.
