vortec head coolant sensor '71 Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2008, 12:59 PM
307malibu's Avatar
I'm trying to get my motor filled with fluid and started. I can hardly wait! But . . . I'm hung up on my coolant temp. sending unit right now. I replaced the 307 in my '71 Chevelle with a 1997 vortec roller block. Problem is, the coolant temperature sending unit from the '71 is too big for the hole in the vortec heads! What do I do from here?
Thanks!
Old 10-07-2008, 01:19 PM
techinspector1's Avatar
Wiki Edits: 326
Ace Hardware in the plumbing department. Male/female reducer with threads on the male end to screw into the head and female on the other end to accept the sender.
Old 10-07-2008, 01:22 PM
lg1969's Avatar
Google "Tunnel Ram 406"
The adapter that screw into the standard 307 heads. Did you removed it and transfer to the new heads you got?
Old 10-07-2008, 02:22 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
You do have a perplexing problem.
The best solution would be, to relocate the temp sender to the intake manifold. If there is not a large enough, or any threaded pipe holes in the intake water runners, drill and tap one.
If you try to reduce the sender down in size with fittings, the sender would not be submerged in the hot coolant flow. Thus, you would get a very false reading. Reading much cooler then the actual coolant temp. Temp senders don't read steam.
Old 10-07-2008, 03:14 PM
406 bug's Avatar
9.82 @ 139mph
Get the reducer, it will read just fine. I would not muck-up the water neck with a fitting- plus, it looks much cleaner not having senders and wires on top of your motor.
Old 10-07-2008, 03:49 PM
SSedan64's Avatar
I agree with Carsavvy, relocate or get a sender that will fit the smaller hole. You do want the probe in the coolant flow, not back in a reducer.
Old 10-07-2008, 06:10 PM
3rdmember
drill it out and tap it for 1/2" pipe threads....
Old 10-07-2008, 06:38 PM
My 2 cents worth
Wiki Edits: 3
I don't believe there is enough 'boss' in the area of the head, to drill and tap it that large. This is why I recommend moving it to the intake manifold area.
Old 10-07-2008, 07:33 PM
307malibu's Avatar
or . . .
Would it be possible to just get a sensor for a '97 silverado, like where the vortec motor was originally from? Or wouldn't that match up with the factory wiring (I'm fine with splicing in a different fitting, but I do want it to actually work good).
By the way, all I'm talking about is an "idiot light" setup. I don't have a fancy temp gauge in my base malibu.
Thanks for the help so far, guys!
Old 10-07-2008, 08:47 PM
My 2 cents worth
Wiki Edits: 3
Resistance values from a 1997, are way different from a 1971.
You need to use the stock sender from the 1971 application. This will work correctly with your dash 'light'/gauges.
Old 10-07-2008, 09:15 PM
I had the same problem when I put vortec heads on my 72 Chevy pick-up. I went to Napa and tried to find a sender that would fit the head but have the same resistance as the original. No luck, ended up putting it in the intake in the hole just under the upper radiator hose.
Old 10-08-2008, 11:36 AM
307malibu's Avatar
Routing the sensor into the intake could've been a good idea, but on the chevelle setup the thermostat housing comes out almost right on top of the 1/2" plug on my intake (edelbrock performer EPS)! There isn't room for the sensor AND the radiator hose. Other ideas? I gotta think this problem has come up with many guys, considering how popular vortec heads are!
Thanks for the help!
Old 10-08-2008, 12:18 PM
My 2 cents worth
Wiki Edits: 3
Can you post a picture of your intake, around the thermostat housing?
I have installed mechanical gauges in 2 intakes before. I know it can be done, even with a factory sender.
The water port runners had a 1/4" wall thickness, and with thread sealant, it will hold, and will not crack. A torque of 18-20 Foot pounds is enough.
They also make thermostat housings that "rotate", (time to improvise) but you may need to get a different upper radiator hose, to make it work without putting a 'kink' in your hose.
In a case like this, you need to be able to 'think outside of the box' to make it work.
Disregard what is the 'given', step back, look, and think 'how can I make this work'. to Hot-roding 101.
Old 10-08-2008, 12:21 PM
406 bug's Avatar
9.82 @ 139mph
Your right, the problem has come up before. When you purchase an AutoMeter temp gauge, the package contains, adapters/ reducers so it will fit most applications (such as yours). If you feel usure of using a reducer based on what others have indicated, call the Autometer folks and obtain direction from them. I think you will find that its ok.
Old 10-08-2008, 12:46 PM
My 2 cents worth
Wiki Edits: 3
What I have seen, the 'threaded' hole in a Vortec head is 1/4NPT.
I have "adapters" in stock, and from what I see, by the time you 'drill' them out to fit the stock "temp sender probe" they will 'break if you sneeze'.............
There is no way this will work!
rant over.
waiting for a 'pic'.
best plugs for a vortec head? runn141 Engine 6 09-05-2008 03:15 PM
LT1 head to vortec head 46 chevy pickup Engine 4 08-30-2008 08:27 AM
Alum Cylinder head seeping coolant externally HotRod60 Engine 12 03-23-2008 11:02 PM
Which vortec head is best? swoodard23 Engine 3 12-30-2007 06:19 AM
Vortec head ? 83GrandPrix Engine 5 02-01-2003 09:33 PM
