Vortec head horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2010, 06:30 PM
How much horsepower can you really expect to get out of Vortec Heads that have been touched up a bit. Got a set on a 355 now. Getting ready to build a 406. Was thinking about using my vortec heads on them. It will be on a street ride.
Thanks Lee
Old 10-15-2010, 07:00 PM
techinspector1's Avatar
Wiki Edits: 326
In my opinion, the intake runners are too small to feed a larger motor. The heads do a fine job on a 355, but a larger motor needs more head. When I do DynoSims, I see them running out of steam on a 383. There will be fellows who will post following this, that they made XXX horsepower with the heads on a 408, but the question is, how much horsepower could they have made with a head that was sized for the motor?
The L31's are 170cc runners. A 408 will need 200cc runners.
Old 10-15-2010, 07:44 PM
I am not a mechanic. But the guy in my neck of the woods that is the "Head Guru" has had sucess porting these heads, then putting 205 valves in them. I don't know all the tech. details. What do yall think
Old 10-15-2010, 08:20 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
I have stock Vortec's on my 406. I don't have any numbers, but it goes pretty good for a 4K lb truck.
I only went with these because I had them. Some day I will get some nice aluminum heads, but the Vortecs are hard to beat when I compare them in my Dynosim program using the parts I have. Of course, I hardly know what I am doing compared to techinspector1.
Hey techinspector, when you say "running out of steam", are you referring to the low RPM range that they seem to peak at?
Old 10-15-2010, 08:35 PM
Overdriv's Avatar
I have a set of 062 Vortecs on a 406, 9.2 compression, 5.7 rods, etc. I did the bowls a bit, screw in studs, good springs, etc. Edelbrock RPM and an Edelbrock 750 carb.
I would have to agree with Techinspector. My engine flattens out between 5000-5500, after that there is nothing there.
My dynosim says 375HP, 435lb/ft torque. For the street it is a hoot to drive. Throttle response anywhere before 5000 RPM is awesome.
With the small runners, I'm not sure you could get a whole lot more from them with bigger valves. That is just an opinion though.
Old 10-15-2010, 10:15 PM
SSedan64's Avatar
Impersonator and Impersonator II SBC406
Check out the Impersonator and Impersonator II articles.
428HP/525TQ Impersonator
http://www.chevyhiperformance.com/te...que/index.html
490HP/525TQ Impersonator II
http://www.chevyhiperformance.com/te...ild/index.html
Vortec head pocket porting david ahluwalia Engine 11 09-24-2010 12:17 PM
Vortec head lift Q's maxpower_454 Engine 7 03-01-2009 08:21 AM
best plugs for a vortec head? runn141 Engine 6 09-05-2008 03:15 PM
Vortec Head Bolts reddwarf Engine 2 02-24-2003 11:56 AM
Vortec head ? 83GrandPrix Engine 5 02-01-2003 09:33 PM
