vortec head modification for .480 lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2011, 02:22 PM
Yes I have searched all over and I don't know what needs to be done to clear a .480 lift cam. Idk what that would cost either, so maybe some guesses? Thanks these are going on my 400 sbc.
Old 09-24-2011, 02:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
CLICK for info on Vortec heads and mods to them, etc.
Old 09-24-2011, 05:30 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
Comp and other cam mfg'ers have "beehive" springs that don't require machining. Some others have posted that some GM 6 cyl engines built now have beehive springs and those will work also.
Old 09-24-2011, 06:15 PM
Okay. I have read that some people are installing comp cams 249-981-16 springs with different retainers and are having good luck with more clearance with out trimming the guides. Wondering if this was true?? Thanks for the link
Old 09-25-2011, 12:57 PM
26915 or 26918 Beehive springs with 787-16 Beehive retainers for over 0.525" lift on stock L31 heads.
peace
Hog
Old 09-25-2011, 08:46 PM
Why wouldn't it be true? They even reference a part number and you wonder if it is true. Hmm.
Old 09-25-2011, 10:06 PM
I don't know why I said that. Must have had the mind going on something. Those comp cam springs I mentioned i know will drop right in, but I was wondering about retainers that would give extra lift clearance. Like maybe low pro retainers. I have seen all the chats about the retainers that give extra clearance I just haven't had any luck finding them. Also I have seen the ghetto grind article. How exactly would you accurately shave off 3/32" from the retainer if I were to keep the stock retainers? Thanks for the input guys.
Old 09-26-2011, 07:08 AM
More drop in Beehive info for Vortec 4.3/305/350 for extra lift.
http://members.shaw.ca/betterthanyou...ec/vspring.htm
I'd rather use a Beehive than the 981. The Beehives smaller retainer is lighter, and acts like a lighter retainer without the cost. The Beehive springs arent the cheapest although teh 2002-2004 LS6 springs are pretty cheap.
Theres a ton of info in this thread along with pics and caliper measurements of how much clearance you can get.
http://www.pacificp.com/forum/viewto...er=asc&start=0
Looks like about 0.560" lift with stock L31 heads with 787-16 retainers and 638 locks.
peace
Hog
Old 09-26-2011, 04:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Never tried this, but someone said the solution is to remove the factory posi lock valve seal and replace with an '86 Daytona 2.2L turbo umbrella style valve seal. Supposed to allow for over 0.500" lift...
Old 09-26-2011, 04:32 PM
Readily available on the internet?
Old 09-26-2011, 05:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What, the seals? I guess- try Rock Auto.
Old 09-26-2011, 06:20 PM
So would those sit right on without it any need for modification to the valve guides?
Old 09-26-2011, 07:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That's supposed to be the deal, but research this first. It's from the 'net, I have no idea if it's valid.
Old 09-26-2011, 08:18 PM
Okay thanks. Well, I'm open to researching stuff so I'll do plenty of that and get back to ya on that. Maybe what you have told me could be another great way to increase lift capacity higher. Offf to the net!
Old 09-27-2011, 11:54 AM
Are the Dodge omni and the dodge daytona like the same thing because when I look up the number I only really find omni seals. If so they are like $2.29 @ O'Reilly's. Not to bad I think.
14102187 casting 305 head modification,outperform a 350 head ??? Calderone Engine 3 05-10-2009 09:09 AM
Vortec head lift Q's maxpower_454 Engine 9 03-01-2009 08:40 AM
Stock vortec head more lift david ahluwalia Engine 6 02-09-2009 10:57 PM
vortec lift under937 Engine 4 08-29-2005 11:43 PM
Vortec Heads / Max Lift? onecoomofo Engine 16 01-27-2004 11:51 AM
