Vortec head studs??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2006, 06:57 AM
I have the Vortec heads from Scoggin-Dickie which have been machined for a .550 lift cam. However, it has the push in style studs. What do you guys feel a safe max lift would be for these heads as is before replacing pushin studs with screw in type? Currently running a Comp Magnum 280H, .480/.480 lift. I want to go to a solid .501/.510 lift cam.
Old 11-11-2006, 08:25 AM
DoubleVision's Avatar
If the cam I`m using is over .500 lift, I go screw in.
Old 11-11-2006, 11:42 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I'm going screw-in for mine at .477 lift just to be safe. It will be in a boat, so it will see a lot of 5000 rpm. I use a sorta expensive shop, but they want $80 for the machine work, and about another $35 for the studs. I can have it done for $60 at another shop but I've had some questionable stuff from them. (just so you know what to expect price-wise)
Old 11-12-2006, 09:22 AM
Vortech 4.3's Avatar
jack of all trades
don't cheap out. get the screw ins. they are much better, and they will make you feel better.
5.7 Vortec Mustangsaly Engine 6 12-07-2005 02:18 PM
vortec head question metalmulisha3x Hotrodding Basics 2 09-17-2004 12:22 AM
head stud's and rocker arm's 70 nova Engine 1 06-26-2003 09:23 PM
leaking head studs!!!! nastynova Engine 4 06-21-2003 08:56 PM
Vortec head ? 83GrandPrix Engine 5 02-01-2003 09:33 PM
