vortec head swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2013, 10:30 PM
vortec head swap
1995 TBI SB 350 5.7 STD> bore block. I would like to know if I can use Flat top Probe PN.2256F Pistons and Edelbrock cam PN.3702 with a vortec head swap?
Old 01-21-2013, 01:03 AM
SSedan64's Avatar
The Pistons wont interfere with the Vortec Heads. The Cam's lift is also within the Vortec's stock lift limits.
Your compression Ratio may be too high tho'.
4.00" Bore X 3.48" Stroke.
2VR Piston w/+4cc, 64cc Head.
.015" Shim Gasket, .025" Deck Ht., .040" Quench.
Cr. = 10.40 to 1
A Piston with a 12cc D-Dish would give about 9.51 to 1 Cr.
14cc = 9.31Cr
16cc = 9.12Cr
18cc = 8.94Cr
The Following User Says Thank You to SSedan64 For This Useful Post:
lowhirod (01-21-2013)
Old 01-21-2013, 06:06 PM
Vortec head swap
What will happen at10.40 cr.?93octane. What will be the best cr? And thanks for the replys
Vortec Head swap ???'s 42CHEVCOUPE Engine 8 12-16-2010 07:28 PM
Vortec Head Swap irippchainsaws Engine 3 06-17-2010 03:18 AM
Vortec Head Swap....Too much compression?? zildjian4life218 Engine 14 01-04-2010 04:40 PM
Vortec Head Swap No start ryankalel Engine 34 05-07-2009 09:23 PM
Vortec Head Swap...do I have everything I need ryankalel Engine 2 04-14-2009 07:12 PM
