Vortec Head Value? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2011, 07:12 PM
1983 Z28
Vortec Head Value?
I have a set of 906 Vortecs that have been hot tanked, checked for cracks, shaved, guides milled, rocker bosses cut, screw in studs and guide plates installed, and have a new set of Comp Cams valve springs and retainers installed.
I bought them this way so I don't know how much was cut off the guides or how much was shaved off. I'm not sure if the spring pockets were cut or not. The current springs measure 1.256" in diameter, but there is a flat surface all the way around the springs where it looks like it was milled.
After checking clearances, I found the heads would be safe for use with a .480-.490 lift cam, or up to .530-.540" with raised locks.
Valves are stock.
Any idea what these things are worth? I got them cheap last year, but now I'm thinking of going with a nicer set of aftermarket heads. They are very nice pieces and will probably end up using them.
Here's a few pictures:
Old 01-03-2011, 07:28 PM
Last journal entry: Paint
Hard to say, they changed hands already. Don't expect to get what some place that sells them new can get for them.
Old 01-03-2011, 07:38 PM
Look on Ebay. That'll give you a good idea on the high end.
vortec head? chewyscool Engine 6 01-13-2010 03:49 PM
Vortec head help!!! crseth Engine 14 07-04-2009 12:13 PM
Vortec head mod jake_arcticcat Engine 6 08-27-2008 12:30 PM
Which vortec head is best? swoodard23 Engine 3 12-30-2007 05:19 AM
Vortec head ? 83GrandPrix Engine 5 02-01-2003 08:33 PM
