vortec heads?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2007, 12:12 PM
Last journal entry: In the beginning
vortec heads??
I'm hoping somebody out there can help with a vortec head question. I can get a deal on some heads(SBC Vortec heads #12558062...1996-up...350...."Vortec 5700", "L31", 64cc chamber, 170cc intake port, 1.94"/1.5" valves) will these work with my 72 400 block as a step up as I put together some cash for a total build up with alum aftermarket heads.
thanks, street
Old 04-03-2007, 12:17 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Depends on how much you want to upgrade. Let us know your target RPM, hp, what kind of car, used where, etc.
Vortecs are the best-flowing production head. A street 400 would be perfect for vortecs. An all-out race 400 might enjoy more flow than the vortecs offer.
Old 04-03-2007, 02:07 PM
Vortec heads on 400 sbc
There are now Bowtie vortec heads available that offer additional performance
potential and (I believe) come already set up for high lift cams and have screw in studs (a must for aftermarket cams w/vortecs) .... come in 170 cc and a larger (200 ? ) size as well ..... I'm not where I can access the literature I had on them . Available via Scoggins Dickey and other performance chevy. dealers .... also available for high lift via SUMMIT , pn:NAL-VORTECZZ5 (set up for 7/16 studs and guideplates but don't include.)
and will handle up to .550 lift @ $780.00 pair.
Old 04-03-2007, 02:20 PM
DeathRattle's Avatar
Some Punk Kid
Are you referring to these?
http://www.jegs.com/webapp/wcs/store...57456_-1_10187
Old 04-03-2007, 02:44 PM
Mustangsaly's Avatar
if you want to run vortecs on a 400 drill steam holes in heads and then you need to do what's required and recommended in this link to run the heads http://www.2quicknovas.com/vortecheads.html
Mustangsaly
Old 04-03-2007, 02:49 PM
Originally Posted by DeathRattle
Those are the BOWTIE units I was mentioning.
Old 04-03-2007, 08:22 PM
spinn's Avatar
agree with f bird.
i would step down to the xe 268, and keep it under 5500rpm. great muscle car workhorse engine.
Old 04-04-2007, 10:33 AM
This Nova is primarily a street / daily driver I'm assuming .... The thing to
keep in mind (beside not going broke building it) is to not go overboard with
the cam/heads/converter/rear gear selection. The vortecs with a moderate
cam (the 268 or 274 would be excellent) say a 750 cfm carb on a good intake (AIR gap performer RMP or similar) the best set of headers and "true" dual exhaust w/crossover you can set up for moderate bucks, and a converter and gears (2600-2800 rpm - ballpark ; 3.42 - 3.73 posi-rear will be a must) ..... a combo like this will produce a ton of torque AND excellent driveability, a sure recipe for fun on a daily basis. One of the things I shoot for in a street car is 12/20; twelve second 1/4 mile with 20 miles per gallon ...
it keeps you "honest" with your build and gives you an end product that's real world friendly ....
ARE 305 and 350 VORTEC HEADS SAME badriand Engine 39 04-06-2011 09:40 AM
Any Experience with Large Port Vortec Heads? ezobens Engine 5 12-30-2006 10:28 AM
XE 268 or XE 262 with Vortec Heads Chevy21 Engine 3 09-06-2004 10:38 AM
XE 268 or XE 262 with Vortec Heads Chevy21 Introduce Yourself 0 09-06-2004 01:51 AM
Exclusive parts for Vortec heads mgray Engine 1 10-16-2003 07:38 PM
