Vortec Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2010, 10:43 PM
Vortec Heads
So vortec heads are a 40 horse bolt on without changing the cam? Any1 know a good deal on vortec intake? Spread bore Thanks
Old 06-17-2010, 12:27 AM
DoubleVision's Avatar
I would use a Edelbrock Performer Vortec. If you use the cheapy professional products intake, you may get a intake that doesn`t have enough material on it`s deck to seal on the heads. Years ago a customer brought a PP intake to me and the intake gaskets overhanged the coolant port by 1/2 inch. The only way to fix the intake would have been to weld it up and machine it back flat. I told him to get a Edelbrock performer Vortec, problem solved. Make sure you use Edelbrock gaskets and Gasgacinch. If you go the Vortec route, and if your cam is over .460 lift, you will have to have the guides clearanced on the heads. Otherwise it`ll make contact and the game will be over.
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 04:17 PM
Cam and valve springs - Vortec heads? staleg Engine 8 02-17-2010 08:31 AM
906 casting Vortec heads and overheated (?) rods darefugee Engine 1 11-09-2009 04:49 PM
Vortec Heads or ??? for SBC Old Rotor Flap Engine 2 10-25-2009 05:25 AM
Exclusive parts for Vortec heads mgray Engine 1 10-16-2003 07:38 PM
