Vortec Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2011, 07:42 PM
Vortec Heads
I'am Trying To Build A 350 Cid Engine Stroker. What Are The Best Vortec Head I Can Used. Thank You
Old 08-26-2011, 07:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You will get a better response posting in the Hotrodding Basics forum instead of the Intro forum.
Anyway, when we say "Vortec" heads, we're talking about the casting number 906 or 062 heads from 1996-2000 (until '02 in selected applications) L31 5.7L engines used in trucks and SUV's. A LOT of info on Vortec heads and mods to them, etc. is HERE.
Old 08-27-2011, 08:04 AM
texas97z's Avatar
Last journal entry: A little progress and maybe new paint
The two castings that Cobalt refrenced above will not take a cam over .420 lift(GM says .440) without modifying either the way they are sealed from oil or maching down the valve spring locators that are cast in the head. If you do neither and run a higher lift cam the bottom of the spring retainer will hit the top of the valve stem seal when using stock replacement valve stem seals.
I just had to do this on a guys truck. 906 casting heads, .503 lift. Luckily the valves in the heads were older style so I put oil skirts and o- ring style seals on each valve and it was good. The best solution since you don't appear to have anything picked out/assembled is to have the locators cut down for extra room.
Old 08-27-2011, 06:50 PM
techinspector1's Avatar
Wiki Edits: 326
The L31 heads will be too small in the intake runners for a stroker motor. The motor will run fine, but you'll be down 100 hp by using them on a stroker motor over the power the motor will make with bigger heads.
I wouldn't use L31's on anything bigger than a 350 unless I specifically wanted to make a low-rpm torque motor that would begin signing off at 4500 rpm's.
You can get away with more static compression ratio using aluminum heads, but I'd be thinkin' about a 9.5:1 limit with iron heads. Match the camshaft accordingly.
Old 08-27-2011, 11:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you can make do w/450 HP and/or want a lot of torque, Vortec heads can deliver.
400 SBC w/Vortec heads: 525 lb-ft of torque and 428 hp 5,500 rpm- http://www.chevyhiperformance.com/te...#ixzz1WFHRvILw
383 SBC w/Vortec heads: 486 lb-ft of torque at a reasonable 4,600 rpm with 449 hp at 5,300 rpm- http://www.chevyhiperformance.com/te...ixzz1WFK7776n-
Also, look through these oft referred to tests for other Vortec engine dyno results- http://ryanscarpage.50megs.com/combos2.html
There are literally dozens if not hundreds of builds/dyno tests of 383 SBC engines using Vortec heads. Just do a search...
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-19-2013 12:00 AM
dart heads vs vortec heads repeat Engine 48 03-10-2012 09:05 PM
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 04:17 PM
Will a intake off vortec heads fit non-vortec heads nobody_1250 Engine 13 12-27-2010 06:02 AM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 05:12 PM
